20 Most Recent Roper RGX4634KQ Gas Dryer Questions & Answers
2answers
How to change capacitor in roper dryer RGX3514PQ0?
What capacitor?
12/31/2015 4:30:41 AM • Roper RGX4634KQ... • Answered on Dec 31, 2015
My roper gas dryer is not heating up,
check the ignter and or fuse
7/5/2015 3:22:15 PM • Roper RGX4634KQ... • Answered on Jul 05, 2015
2answers
I moved and cannot locate the pilot/ignition source on the dryer to relight it.
It's been many, many years since dryers had pilot lights. Look for an igniter that may have gone out. It should be behind a service door.
5/30/2015 4:42:47 PM • Roper RGX4634KQ... • Answered on May 30, 2015
0answers
WHY IT'S RUNNING,BUT NOT HEATING?
The only simple answer to this question is the flame is not working. Then the question is why not? That's when it gets complicated. In the old days there was a pilot that stayed on to ignite the flame.Today the pilot is electronic and needs a signal to operate.So is that pilot working...is it getting the signal to work? Suppose that it is then your question is about the gas. Is it present? Turned on maybe. Say that it is. Well there is a fail safe valve that turns on only if it senses the presence of the pilot.That valve also has to have a signal present to turn on.That's pretty much it. No simple answer to a broad question.
2/13/2015 2:38:33 AM • Roper RGX4634KQ... • Answered on Feb 13, 2015
How to replace a dryer switch Roper
Hi J L B , I could help you with that . With a Phillip screwdriver remove two screws under the lint screen , next remove the two screws on both sides of the door switch . Now pull the top panel towed you and lift . Finally disconnect the old door switch and replace it . Good Luck APPLIANCES R EN
4/28/2014 9:32:54 PM • Roper RGX4634KQ... • Answered on Apr 28, 2014
Why does`nt dryer shut off when in auto dry mode ?
sounds like your thermal switch is bad I’m happy to assist further over the phone at https://www.6ya.com/expert/jaime_a0afdb97baa63a3d
4/28/2014 4:17:54 PM • Roper RGX4634KQ... • Answered on Apr 28, 2014
Roper repair manual
You can try this site:
4/15/2014 5:59:49 PM • Roper RGX4634KQ... • Answered on Apr 15, 2014
Drier keeps running
Sounds like you have a bad timer
3/24/2014 6:35:16 AM • Roper RGX4634KQ... • Answered on Mar 24, 2014
My dryer run all day and night if I would let it.And it takes one day to dry my clothes what is wrong with it
If it gets hot or warm in the drum but the clothes do not dry---the most common cause is a blockage between the drum, lint tube in the unit to the vent that flows the air to the exhaust outside.If the drum gets much hotter than the air exiting the vent----clean all the from the drum to OUTSIDE.Note: if there is not proper airflow and a lint build up exists there is the potential for a fire---Hundreds of fires are reported each year cause by this kind of trouble.If the drum does not get hot inside you may have a bad igniter that heats the air (fires the burner uo inside the unit.)
12/7/2012 8:52:35 PM • Roper RGX4634KQ... • Answered on Dec 07, 2012
My gas dyer makes a
Could you please describe the problem you are having a little better?
11/1/2012 3:51:09 PM • Roper RGX4634KQ... • Answered on Nov 01, 2012
I need to change belt
Hi jfinto1971ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.Note: This method works for most front loading machines.If you have to check/replace/repair your drum motor,drum seals,belt,rollers, etc.If replacing drum seals be sure to use a good grade of weather proof cement to hold the seal/s in place, some seals are furnished with the cement to glue it in place.Remove the electrical console that holds the timer switch,start switch, etc. from the top of the dryer if necessary. Be real careful not to knock any of the wires off of the timer switch or other electrical connections. Remove the lint filter and the two screws that hold the filter housing to the top of the dryer lid.Then remove the top of the dryer by inserting a screwdriver between the top and frame on each side of the dryer to pop the lid up from the retaining clips.Note: Some of the tops tilt backwards on a type of hinge and do not have to be removed completly.Remove the front of the machine by disconnecting the door switch and removing the two screws located on either side of the dryer frame.Move the door and front of machine forward to remove.This will expose the belt,idler bracket and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. Pay attention to the route of the belt, this will come in handy when you go to reinstall the belt and drum.Sometimes the belt will slip off of the idler arm or motor causing the drum not to turn.Note:The way the belt goes back on is, as the belt comes off the drum has to be doubled (pushed together to form a loop) and goes under the idler pulley then to the motor pulley.Here is a link to see a picture of your belt routing in case the belt is broken when you open your dryer:http://www.expertappliance.com/dryerbeltconfiguration.html While you have the drum out, I would recommend that you remove and lubricate the drum rollers.And also clean the shafts of the rollers as they will collect hair,dust,etc and cause problems and then lubricate the shafts and rollers with a good grade of machine oil like 3 in One oil or a vasoline type of lubricant. This will save you a problem later with the rollers getting dry and making a squeeling noise, also check your drum rollers for flat spots, if they have flat spots on them this will cause a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.Please take time to rate me Bud
10/9/2012 1:30:22 PM • Roper RGX4634KQ... • Answered on Oct 09, 2012
Burner goes off after 5 seconds
Replace the high limit switch. Here is a link to the part.
5/23/2012 8:43:22 PM • Roper RGX4634KQ... • Answered on May 23, 2012
I've got a 4 yr
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
5/19/2012 8:07:59 AM • Roper RGX4634KQ... • Answered on May 19, 2012
Ignitor is lighting, going out after a few seconds,dries sometimes but mostly not drying
Hello Amy,With the igniter coming on and then going off, yet their is no heat to the dryer the problem is going to be bad coils for the gas valve that need to be replaced.This is a tip i wrote about the coils it includes the part number and instructions of how to replace them. http://www.fixya.com/support/r10174506-gas_dryer_starts_off_hot_but_after_whileGENE
11/14/2011 12:27:50 AM • Roper RGX4634KQ... • Answered on Nov 14, 2011
Roper RGX4634KQ Gas Dryer Logo
239 questions posted
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
View Most Popular
Roper Dryers
  • Roper Dryers
Most Popular Question
  • Dryers
