Thank you! I also want to know how to connect a can bus cable to the motorcycle and the GPS. The info about this from Touratech is kind of hard to understand.Thank you! I also want to know how to connect a can bus cable to the motorcycle and the GPS. The info about this from Touratech is kind of hard to understand.
You can't post conmments that contain an email address.
You have an electronic fuse box, if it is tripped, it will reset itself once the problem is rectified and you switch the ignition off and on again. Go to this site and down load a free Owner's manual:
Check your owners manual for location of your fuse box. You will probably find connections for accessories. If not make sure you use an inline fuse on the positive connection and then ground to the frame.....Good Luck and Nice Bike!
