20 Most Recent
Garmin zumo 550 GPS Receiver Questions & Answers
Call 1-8O5-225-669O GPS/GARMIN Update-Install-Download-Fix We are 24 Hour Available Call Now For Help
I just got off the phone with tech support. They have a very
complicated fix that involves remote accessing into your computer and
editing files, etc. They said it would take over an hour and a half, I declined.
The problem apparently is that the nuvi 200/205 can't support canada, but
the maps contain canada = problem. and btw, i downloaded "City
Navigator Lower 49 States+PR NT 2010.10, Deluxe, Apr 09" and got the
same problem. this filename ends in a "B", apparently that's the
"fixed one" but acc tech support it's only fixed in the sense that they
can waste over an hr w' u fixing it, whereas the older files are
unfixable.
I'm just gonna wait til they really fix it and upload those files.
Hope that helps.
I cannot get audio at all for my garmin zumo 550.
The 550 relies on the car base for audio as it has no speaker. If the base is not powered up it will not amplify the sound out of the GPS unit, Check the in-line fuse on the power cord, it is usually located in the tip of the cigarette lighter adapter. twist off the tip and this should expose a fuse.
HAve you tried connecting to it with a bluetooth headset, this should work regardless of whether or not it is on the base.
Hope this is of some help.
Ed
Garmin zumo 550 map update problem
- Make a backup of your Zumo by copying all the file to your computer.
- Using your PC and MapSource select all the maps then send them to a SD memory card need 2Gig or bigger card.
- Try to rename this file to gmapprom.img and replace the same named file in your zumo. (I haven't tried this personally, so if it fails, just replace this with your backup and all will be as it was.)
- If this fails, you can use the SD memory card in your zumo and it will use this map instead, but it will take longer to boot your zumo.
GARMIN WILL NOT TURN OFF
I have the same problem. Seems to happen when I get a photobox warning in a tunnel an after that loose satelite connection in the tunnel. This has happened two times at the same place, The only solution I`ve found so far is to take out the battery and start again. Hopfully there will come a software update for this soon!
Bluetooth icon missing
Possibly does not have bluetooth available on this model. Some Garmins have Bluetooth and some don't. If you have used it before with bluetooth, check your systems settings to see if you have turned off the bluetooth function.
