I have a 500 gig toshba external , plug and play , storage drive. itwill not open on my dvd player
Does the computer recognize the 500GB Drive when you plug it into your usb port?
Click Start/My Computer and see if your 500GB drive is listed as a device, if not that's a problem.
Try using a different usb port. Also try using the 500GB drive on another computer.
If it's gone belly up, it's not going to work.
SOURCE: verbatim 500 gig hard drive not reading
Clicking is generally a bad sign as it indicates the harddrive is seeking over and over not getting a read of the pallets (think arm on a record player swinging back and forth with no needle).
Good news is if it's just the control cicuitry the drive can usually be recovered for under $500. If the failure is internal rates can range from $700-$5000 depending on the level and type of damage.
If you think you would want to try either of these methods get back to me and I can recommend appropriate service providers for either.
Sorry it's not better news,
Chris
SOURCE: Problem with seeing files on external Hard drive
What has happened is that your file system on the hard drive became corrupt becasue windows had not updated the MFT on the drive. THe MFT is a table of contents regarding whats on your drive.
What happened is similar to someone cutting out a few pages of the table of contents in a book that has a lot of pages.
Windows tried to fix this stupid programming method by asking people to always use the "safely remove hardware" button in the taskbar to force it to update the MFT.
In this case yur a victim of the Hard Discs MFT not updating properly probably because software was accessing the drive when it was disconnected from the machine.
You need to run chkdsk to have it rebuild your MFT.
http://support.microsoft.com/kb/315265 <-- How to perform Check disk
*NOTE: Remember to use the drive letter that the USB External is on.. Not just type CHKDSK. It will default to drive C to scan for errors. ex: c:\chkdsk g: (where g is the drive your external usb is)
If you get an error like "CHKDSK is not available for RAW drives.. see my notes below.
Beware that it will take a LONG TIME to perform this procedure.
If this doesn't fix it.. contact a data recovery specialist.. It's worth the cost. There are two types. Simple and Advanced.
Simple= recovering files your deleted with the delete button (fairly easy with the right software)
Advanced = recovering files from a hard disk crash or file system corruption. (Not easy and very time consuming)
SOURCE: reformatting an external hard drive
Id you have a xp disk when it loads it will ask you how do you want to set up the drive even though you have and external drive on your computer in the my computer icon Right click and open manage open disk management and you should see your usb drive right click on the drive and you should see format it has a dropdown menu check quick format and click ok and it will start to format the drive make sure you chose ntfs in the drop down menu .good luck
SOURCE: my wd 500 gig external hard drive keeps blinking
How do you have it connected to your PC? USB or Firewire? try plugging it in to different slots or try plugging it in on another computer to further isolate the problem. some external drives requires power adapter to work so make sure that you're using the power adapter if it comes with the device. if not, there might be something wrong with the device specially if it was working before
SOURCE: I cannot see my free agent external drive
Thanks for your responses...
I've pretty much decided that it must be a hardware problem within the harddrive itself...Can anyone lead me in the right direction to maybe take out the harddrive to put into another external shell in order to hopefully recover my data? Again I'm using a Seagate Freeagent Desktop 500GB external harddrive.
My HP laptop successfully recognises the drive, its plays on every desktop/ laptop i plugged it into..problem is that my pioneer dvd player does not pick up the drive at at all. Blue light on the drive is on , but the dvd player is just NILL.
Yet it picks up my older Toshiba portable storage. Plugged it directly into my LG LED TV ( forgot it also has usb ports)..and the TV picks up the new drive, AND the older one. Why the dvd player wont read it ...anyone??? Its gonna bother me until i know WHY.
