20 Most Recent Toshiba (1TBEXT-HDD) (1TBEXTHDD) 1000 GB Hard Drive Questions & Answers
I have a ph3200u-1exb usb/esata drive. It was
u can try reaching one computer wizards to handle for you
9/6/2017 9:59:22 PM • Toshiba... • Answered on Sep 06, 2017
2answers
I pluged my Toshiba Canvio Plus 750gb External HD
Sounds like a 2 part question.
Part 1, how do you use the drive on the computer to watch recorded shows from you DVR, simple install EX for windows which will allow your computer to access Linux formatted drives.
Part 2, how do you retrieve the files that were on it before, that depends how many new files you've put on it since. When the DVR formatted the drive it didn't erase the old files and they could easily be found again with a very inexpensive program. Each show you've recorded since will have overwritten some of the files. I will give you a link below for a review I wrote of such a program. Don't buy it right away, download the trial and scan the Toshiba, the program will show you a list of files it can recover then if you think it's worthwhile for the files it shows, only then pay for the program and recover the files.
Link for EX?
http://www.fs-driver.org/download.html
The author provides this driver for free but asks you donate to show your appreciation.
Data recovery software:
http://www.aitsavemyfiles.com/reviewfilerecoverybypctools.php
Hope this helps FixYa,
Chris
4/29/2015 8:19:06 AM • Toshiba... • Answered on Apr 29, 2015
4answers
How can i format 1TB Toshiba Canvio portable hard
Right Click on your new drive in the Computer
Choose a File System (NTFS is ideal most cases) and give the new volume a name if you choose. You might like to call it something like "Portable Drive," or "Removeable Drive." If not, just take the defaults and click "OK."
You will get one last warning that you are about to format your drive and erase all data. Click OK to proceed. When you see the process has reached 100%, you are done and you're new external hard drive is ready to use!
10/3/2014 7:40:46 AM • Toshiba... • Answered on Oct 03, 2014
2answers
[email protected]
how can i personalize my hd
7/11/2014 4:51:27 AM • Toshiba... • Answered on Jul 11, 2014
6answers
I have toshiba cavino 750gb
Don't be panic. you can try some format recovery software. You can seehttp://www.asoftech.com/adr/It tells the steps how to perform data recovery.If above does not work, you may have to format the hard drive (use quick format), and then use above mentioned software to scan again the hard drive and recover your files.
1/13/2014 2:00:49 AM • Toshiba... • Answered on Jan 13, 2014
When showing movie cant read the whole film,freeze
try copying the movie to pc....if entire file copies then there should be no problem playing it...if it cant copy or read there there must be some problem with the file or hdd.....
12/30/2013 4:51:09 AM • Toshiba... • Answered on Dec 30, 2013
SLOW OPENING FILES
don't leave files in open directory. arrange all files into separate folder. if you have saved flv videos, put them in a seperate folder. then defragment the drive. install sata driver, if the problem continues.
12/14/2013 2:03:39 AM • Toshiba... • Answered on Dec 14, 2013
When i plug in my hard the computer reconize it but it says:you should format it before you can use it.
Save all the data to a cd or gig stick or an external storage unit. Then format it. and copy back from the storage unit.
6/9/2013 9:32:41 PM • Toshiba... • Answered on Jun 09, 2013
I have a toshiba 1tb external. it worked fine today at work and when i came back to use it on my laptop it wont work. it wont blink, no noise that the computer detected the hard drive. NOTHING! my lif
click start control panel administration tools computer management device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red xright click to reinstall drivers or
if you can see your usb but its not workingports(com&lpt)right click update driver
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems
if this fails to fix the problem type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter. Then restart computer then check. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4
if still no luckyou might have to install a usb 2 or 3 card they are cheap and easy to install you can buy these on Ebay very cheap hope this helps
4/13/2012 3:38:06 AM • Toshiba... • Answered on Apr 13, 2012
I have a Toshiba 1TB
plug it on the back of the panel not on the front, or try to plug to other computer, if the problem still thesame then your external drive would be the problem.
9/1/2011 4:35:12 AM • Toshiba... • Answered on Sep 01, 2011
Every time i connect my
Has the disk come with a usb cable that has 2 big plugs?If yes:Try plugging both in.If no:Take your device to customer care.
7/2/2011 12:30:59 PM • Toshiba... • Answered on Jul 02, 2011
I have just tried, for
External harddrives do not come with an O/S. They are for external storage, beyond the master harddrive you have installed.
The master harddrive has the O/S.
The Platters are spinning because BIOS had a look to see what is on the Toshiba 320GB external harddrive.
[You press the Power On button. The first chipset to receive power is the BIOS chipset.
(Basic Input/Output System)
BIOS looks to see what devices are connected to the computer, does a Ram Memory count, turns the Processor on, then hands the computer over to the operating system.
BIOS finds THE harddrive with the O/S on it ]
http://en.wikipedia.org/wiki/BIOS
http://computer.howstuffworks.com/hard-disk.htm
When the Windows O/S (Operating System) is installed on a computer is assigns hash values to certain major hardware components in the computer.
A) Processor
B) Harddrive
C) Motherboard. (Motherboard chipsets and BIOS software on the BIOS chipset)
D) Graphics chip. (Whether it is Integrated Graphics, {OnBoard}, or a graphics card)
Change any two of these hardware components and Windows throws up a 'red flag'.
Microsoft's User License states, "One genuine copy of Windows per One computer"
If a hash value has changed, such as there are different hardware components, Windows 'feels' it is being stolen.
Why do you feel there should be an O/S already installed on the external harddrive?
Awaiting your reply please state in a Comment.
Regards,
joecoolvette
6/10/2011 4:04:09 AM • Toshiba... • Answered on Jun 10, 2011
I purchased my Toshiba 1
If your computer or laptop has a problem detecting a USBhard drive or a USB device, and another computer can detect it, then theproblem could be a RF interference problem. Try using an USB cable that is a shielded USB cable (ie. AnUSB cable that has a clear plastic covering and you can see a metallic weavewhich covers the wires) OR a USB cable that has a Ferrite core attached to theUSB cable (the ferrite core is a cylindrical object approximately 30mm long X15mm diameter and it is attached to the USB cable near the connector).
5/30/2011 10:21:30 AM • Toshiba... • Answered on May 30, 2011
2answers
I bought thisToshiba Canvio 1TB
Since you have bought it just 3 months ago, I assume it is still covered by warranty. If this is true, I recommend you contact your vendor & discuss the possibility of having a replacement.
In case you need any further assistance, please feel free to drop me a note.
5/12/2011 5:31:07 PM • Toshiba... • Answered on May 12, 2011
I plug in my hard
Hi, please connect the external Hard Drive to different USB port of the Computer. If you are using the Desktop Computer then please connect the Hard Drive to back side of the USB Port. Then make sure that Hard Drive AC Adapter is connected and working. Also check if the Hard Drive is working with any other Computer.
3/30/2011 6:16:34 AM • Toshiba... • Answered on Mar 30, 2011
As soon as i plug
Make sure that you have the right software installed and or your usb ports are working
3/24/2011 2:03:53 AM • Toshiba... • Answered on Mar 24, 2011
Hi! i have an external
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files. For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge" guarantee.
12/23/2010 4:44:34 PM • Toshiba... • Answered on Dec 23, 2010
Computers & Internet Logo
38 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Toshiba Computers & Internet
Most Popular Question
format 1tb toshiba canvio portable hard
  • Computers & Internet
