20 Most Recent Toshiba Satellite A135 Notebook Questions & Answers
Can not booting
2007 PC it is so is not too old. the new PC in the box (NIB) the papers in the box told you to charge it first. for 12 hour , or over night did you do that? both batteries, in the PC must be charged first; and the big battery loves to fail if abused. even 2 years old . abuse is over or under charged. most times modern PCs avoid the overcharge act. but under charged is easy, just throw the PC in a closet fore 2 years and bingo, battery is bad or degraded huge.
4/12/2022 10:55:33 AM • Toshiba... • Answered on Apr 12, 2022
NO PICTURE ON MY TOSHIBA SATELLITE #L305-S5885 DVD PLAYER OR WINDOWS MEDIA PLAYER, CANNOT PLAY DVD'S!
try to update your media player.if possible windows media player 11. If still it doesnt work try to check your direct X installed components. Try to update it also. next try to check your display driver settings maybe your display driver isn't working. check it by running the run command and type dxdiag to check your computer system go to the display settings and check if there are any installed driver.
12/20/2021 7:57:44 PM • Toshiba... • Answered on Dec 20, 2021
3answers
Toshiba Satellite Laptop DVD Player
Mac Optimizer Pro helps you to keep your Mac optimized by deleting redundant files. With its One-click Cleaning feature, you can recover valuable disk space on your computer. It has also come with Junk Cleaner, Logs Cleaner and other features for thorough cleaning. With its optimization features to find duplicate files, unused and old files, large files and old downloads, you can sort your disk storage in no time. Another than this, you can also delete files from trash, remove old backups and download to keep your system organized. To know more, Contact us at 1 866-252-2104 or visit:- https://www.macoptimizerpro.com/ mac-optimizer_pro-undefined-undefined-0.png
3/27/2020 10:42:03 AM • Toshiba... • Answered on Mar 27, 2020
2answers
Default bios password toshiba satellite a135-s2276
Some Toshiba's can be convinced to bypass the startup BIOS password if you hold down the <LEFT-SHIFT> key while booting the system.
1/8/2020 8:08:12 AM • Toshiba... • Answered on Jan 08, 2020
2answers
Keyboard inoperative
press and hold fn and press f11.it sounds like you activated the sticky keys
11/26/2018 11:58:09 AM • Toshiba... • Answered on Nov 26, 2018
High definition audio controller This device cannot start. (Code 10)
If you run into the error "This device cannot start. Code 10 (often followed by a driver identifier, for example "This device cannot start. Code 10 in audio driver"), here is what it means. The Windows error "This device cannot start. Code 10 or "This device cannot start. (Code 10)" is a hardware error that most commonly means that you have a bad, missing, or incompatible device driver. So, for example, "This device cannot start. Code 10 in audio driver" means that you have a bad or missing or incompatible driver for your sound card. The technical explanation for this message, according to Microsoft, is this: "If the device has a FailReasonString value in its hardware key, that string appears as the error message. The driver or enumerator puts this registry string value there. If there is no FailReasonString in the hardware key, you receive the following error message: This device cannot start. (Code 10)" What does that mean in plain English? It means that if the device which is throwing the error has added its own custom error text to your Windows system when the device was installed, then when the device encounters an error, you will see the custom error message specific to that device. But if it doesn't have its own custom error message, then Windows uses its own generic error message for devices, which is "This device cannot start. (Code 10)" Microsoft recommends that when this happens, you click "Update Driver" to update the drivers for the device. You can also start the Windows troubleshooting wizard by going to the general properties tab of the device, and clicking on "Troubleshoot". Before doing this, be sure that you have the correct and most up-to-date versions of the driver(s) for that device. You can also try uninstalling and reinstalling the device, using the disk which came with it. Finally, you can go to the website of the device's manufacturer, and check their downloads or support section for current, up-to-date drivers. Go to Toshiba support site look for Toshiba Satellite A135 drivers, download the one for your windows 32 or 64 bit install, restart and off you go. Regards, Mike
4/7/2016 6:23:21 PM • Toshiba... • Answered on Apr 07, 2016
A665-s6094
Yes and no...Yes, you can add this module:
  • Part Number PA3710U-1BTM
  • Description: Toshiba Bluetooth 2.1+EDR USB Nano Adapter
This will enable bluetooth functionality...There are drivers for the bluetooth stack on the support website: Satellite A665 S6094 Support Toshiba But no, bluetooth is not built in...
8/3/2015 9:32:25 AM • Toshiba... • Answered on Aug 03, 2015
Taking forever to connect with enternet
Try connecting at different times of the day. It may not be a problem with your ISP not you. There are certain times of the day when my connection drops by 90%. My hardware is the same so its just down to a local bottle neck. Connect your ISP. If you run Speedtest or another connection testing application you can get some stats on how fast your connection is running. With this information you can contact your ISP. http://www.speedtest.net/
4/19/2015 7:36:24 AM • Toshiba... • Answered on Apr 19, 2015
Fn is not work, so how to mimimize brightness of M115-s3154 toshiba laptop?
have you tryed going into your display settings?
4/12/2015 2:43:30 PM • Toshiba... • Answered on Apr 12, 2015
Default bios password toshiba l305-35909
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot
3/12/2015 12:18:45 PM • Toshiba... • Answered on Mar 12, 2015
Default bios password toshiba l305-s5909
Most Toshiba laptops and some desktop systems will bypass the BIOS password if the left shift key is held down during boot.
3/12/2015 12:18:41 PM • Toshiba... • Answered on Mar 12, 2015
If the keyboard is not working it also affected the touch pad in the travel mate 4740 ?
The keyboard and touchpad each have separate ribbon connectors that can get disconnected from the motherboard. After gaining access by undoing case screws, the repair is easy remembering to push in the flat retaining bar that keeps the ribbon connectors tight against the motherboard.
5/26/2014 2:06:26 AM • Toshiba... • Answered on May 26, 2014
0answers
Driver download
Be the first to answer 1/19/2014 4:30:09 AM • Toshiba... • Posted on Jan 19, 2014Be the first to answer
No icons
To enable missing icons and more, right click on your desktop and choose Properties. Click on the Desktop tab and hit the Customize Desktop button. Next, under the General tab, check off any of the icons you want to appear on your desktop.
Once you do that, they will all be returned to your desktop in full view. You can choose from the icons of My Documents, My Computer, My Network Places and Internet Explorer. Now, on the other hand, you may want to take some of those icons off your desktop. If that's the case, just uncheck them and they will be out of your way
10/23/2013 5:40:32 PM • Toshiba... • Answered on Oct 23, 2013
2answers
I have a toshiba A135-S4656. The fan needs replaced or a cleaning
Getting to the fan on your laptop is VERY DIFFICULT. There's a lot more screws, wires and snaps holding the computer together than you'd imagine. It's best to get a professional to do it, however less and less people these days are willing to pry open someone's laptop because a lot can go wrong.
If you've backed up your laptop and are willing to risk not being able to put it back together, then go ahead. To get to the fan you actually need to get through the top. Unscrew every screw you can find on the back and the bottom. You'll need to open up the hard drive and motherboard because there's screws there too. Pry off the piece covering your speakers, then the keyboard, then unplug the ribbon wires by moving the little plastic things, all the while unscrewing everything you see. Good luck.
9/1/2013 5:19:06 PM • Toshiba... • Answered on Sep 01, 2013
Is bluetooth is present in toshiba core2 duo t6570
I believe you will need a Bluetooth adapter for that.Only $4
2/16/2013 1:41:13 AM • Toshiba... • Answered on Feb 16, 2013
Need to replace dvd player in Toshiba Satellite C655
http://www.youtube.com/watch?v=ChrYyWjaEMY Toshiba Satellite C650 L675 DVD Replacement Guide Installation -- L670 C655. Install Fix Replace CD DVD/RW Optical Drive Burner. This guide is useful for these laptop models: TS-L633 - 142, V000210060, C655D, C650D, L675D, L670D
1/30/2013 5:37:10 AM • Toshiba... • Answered on Jan 30, 2013
Buletooh drive
Does your computer have bluetooth software? You can look in Control Panel for the Bluetooth software click to open go to settings. If you do not have it you can get a bluetooth USB device.
11/21/2012 6:15:13 PM • Toshiba... • Answered on Nov 21, 2012
I ONLY GET A BLACK SCREEN WHEN I TURN THE COMPUTER ON
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
5/21/2012 10:40:23 AM • Toshiba... • Answered on May 21, 2012
Toshiba satellite m305d power light
Either your motherboard, CPU, or GPU have fried. You can try to re-seat your ram but if there is no beep/beeps and nothing but a power light, and fan running for a couple seconds those are the only options. If your handy you might get lucky and get it to work for a little (as long as you have thermal paste) Remove heatsink, & fan, then the CPU blow out the connections with compressed air (to go the extra mile electronic cleaner) then let dry for a few hours reassemble, hoping for the best the whole time mind you.
6/21/2011 3:20:46 AM • Toshiba... • Answered on Jun 21, 2011
Toshiba Satellite A135 Notebook Logo
279 questions posted
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
Satellite Toshiba
  • Satellite Toshiba
Most Popular Question
need know
  • Computers & Internet
