Well the digram is not available saperately you have to buy the service manual for this digram. If you want to buy it from net then please visit the link below -
http://www.themanualsworx.com/simplicity%20broadmoor%20717%201968%20chassis%20onlysvc%20service%20svc%20manual-p-15204.html
It's available for $57.59 USD.
Regards
SOURCE: Need wiring diagram for Simplicity lawnmower
simplicity is owen by B&S power corp. there my not be a down load, your my have to contact a dealer or call magneto power or log on to there web
SOURCE: Simplicity Broadmoor only runs for a minute or two and then quits
Check both the air and fuel filters. Either being clogged would give this situation. It could also be dirt in the fuel line. Disconnect at both ends and blow them out. If none of the above helps, then the problem is likely in the fuel pump or carburetor and will take some disassembly.
