Water dripping inside..can hear water filling up but no ice cubes forming and dropping in bin
SOURCE: Hoshizaki KM-1600S too much water supply
If water is standing in the bin the drain is clogged. If water is raining down into the bin, Machine may not be level or the drain on the ice machine maybe partially clogged. If machine freezes up water will rain into bin too. Water fills ice machine while in harvest and continues to fill until ice machine`s suction reaches 49 degrees and the defrost timer times out.(usually 1-3 minutes after suction line reaches 49 degrees)
SOURCE: hoshizaki ice/water unit beeping-unit new-operating 1 month
800-233-1940 is our tech. support or look at
http://www.hoshizakiamerica.com/techsupport/tech.asp?
SOURCE: Why is my Hoshizaki ice machine evaporator frozen
if the defrost/hot cycle doesn't work, the ice won't fall and eventually freeze everything.
Testimonial: "Thanks, I should have indicated that this machine is water-cooled & problem does not develop until bin is full of ice; does your solution still apply?"
SOURCE: Hoshizaki KM-600mah beeping
PCB requires to be reset. White button power needs to be on or it wont reset.
SOURCE: I STARTED A HOSHIZAKI TOOK TAPE OFF CURTAIN
Start by looking for water valve leaking. Turn machine off and if water is entering machine, water valve is not seating. Let me know if you need more than this.
