They marine ice makers are fussy. The ice maker needs to be level or water will drip down into the ice bin. The amount of water entering the tray is controlled by time. The other factor is pressure. The marine water system has a relatively low water pressure as compared from marina water feed.
I would confirm the number of cubes produced from the unit when connected directly to the city water pressure. If at the highest pressure it is below expectations I would follow the video. How Do Adjust an Icemaker Home Appliances
There is a screen filter before the solenoid line that can fill with debris. So you may need to check it if you can not make a satisfactory adjustment.
If you are like me and always work form the internal water tank avoiding a burst water line and "sink the ship" then adjust it for the lower pressure.
Happy Sailing
Ok 32 deg is freezing. If compressor is running and condenser fan is running and refrigerant psi is good then lets check Malfunctioning water valve assembly, check to see if you are getting water to water valve if so then check to see if you are getting power to water valve. Check mold heater, you don't want mold heater on at this time. It sounds like you are having a water or water valve issue.
Kenmore is a brand name of household appliances. Thebrand Kenmore, as of 2010, was owned and soldby Sears Holdings Corporation and Kmart. Kenmorehas a line of refrigerators and freezers with built-in automatic ice makers. Bylifting the the signal arm, the ice maker sends a signal to a valve to turn onand release water into an ice tray. The water freezes in the trays and a sweepfork pushes the ice cubes into the holding bin.
Instructions.
1Lift the cover of the automatic ice maker. Lift the bottom of the cover andslide the cover over the top of the ice machine.
2 Turn on the automatic ice maker. Reach into the icemachine and lift the signal lever. The signal lever looks like a bent coathanger. Move it upwards to the "On" position, using your hand.
3 Close the cover to the automatic ice machine. Pullthe cover from the top of the ice machine and cover the ice bin.
Thanks.
