20 Most Recent
Imperial IFS40 Deep Fryer Questions & Answers
Dial is set to off. Why does main burner still light?
The thermostat could be stuck in the on position . Remove the wires and do a continuity check on the two terminals on the thermostat. Should read open with the thermostat in the off position. Also check that someone has not jumped the two terminals on the gas valve.
Why does pilot go out?
Greg. Either pilot flame needs adjusted, or you have to replace thermocouple.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
What does the gas adjustment screw look like on a
There is no gas adjustment screw. There is an air ratio adjustment on each burner. Loosen the screw that holds the flame adjuster and turn the stamped metal adjuster until there is no orange portion of the flame visible. Tighten the screw and you're done.
Imperial ifs40 fryer suiting up.
If you don't know that you are doing you should buy them. You need one for each burner, 3 or 4 for most models. Yes they can be drilled out going only one way, using lettered drill bits that are hard to find. The regulator on the back normally has to be adjusted also. If either is wrong, the flame will be to big or to small to heat correctly. At least buy one orifice and check the size hole, they are not expensive $5 -$10 if you do a little searching for a good price.The Part Numbers are:Orifice - NAT. Gas 1625-36Orifice - L.P. Gas 1625-51You MUST use Lettered drill bits for size, Like A-Z If it was drilled with any normal size bits 1/16 type bits it will NOT be correct! There should be a number stamped on the orifice, unless it was drilled out. Most people never mark the door that the gas type was changed, causes all types of problems for the service men.Can you give more details to your problems? I couldn't find the hole sizes right off, but have seen it listed.
Why is my Pitco 65c+ is burning yellow
Could also be the amount of air getting into each burner. There should be a metal ring with holes on the front of each burner. There should be a set screw to keep it from turning by it self. Loosen the screw and turn the ring until the flame burns better and tighten the screw back again. If the orfice is the wrong size for the gas you have, it might be able to be drilled out or needs replaced if it needs to be smaller. You will need the manual to find out the correct size orfice, it will be a letter size of a drill bit, some what hard to find.
Have you had any recalls on this product?
Hi there.
If the bubbles come up after loading products on fryer, check the product load quantity and reduce as needed so oil will not overflow. Bubbles came from the water content of the product; more water inside the product, the more bubbles it will produce during cooking so it it better to check the loading quantity.
Regards.
