Is there a way for me to do a system restore from my windows xp bios menu?
My emachines T3516 will not boot Windows xp. Safe mode, safe mode with networking, & safe mode with command prompt are not options. When I click on any of them a ton of script appears and there are no options displayed. My screen freezes on the script for a few seconds, displays a "no signal" message, and then returns to the boot menu.
I had an adventurous itch to suggest you run safe mode repair following a successful boot but sanity returned. You are better off following normal recovery procedures as you have so much down.
You need to repair your windows xp installation. Insert the xp install cd and power off - then power on your pc. If the screen says "press any key to boot from cd" then do that. It takes a while until you get to choose options. Choose the repair previous installation option by pressing the R key when prompted. Follow the instructions on the screen and you should be fine.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu Please select an option: Safe Mode Safe Mode with Networking Safe Mode with Command Prompt Enable Boot Logging Enable VGA mode Last Known Good Configuration (your most recent settings that worked) Directory Services Restore Mode (Windows domain controllers only) Debugging Mode Start Windows Normally Reboot Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
To use System Restore, first restart the computer by pressing[Ctrl][Alt][Delete]. When you see the message Please select the operating system to start or hear the singlebeep, press [F8] to display the Windows Advanced Options menu. Now, select theSafe Mode item from the menu and press [Enter].
Once Windows XP boots into Safe mode, click the Startbutton, access the All Programs ' Accessories ' System Tools menu, and selectSystem Restore. Because you're running in Safe mode, the only option on theopening screen of the System Restore wizard is Restore My Computer To AnEarlier Time, and it's selected by default, so just click Next. Then, followalong with the wizard to select a restore point and begin the restoration procedure. Let me know if it helps you. Use system utility tool like RegInOut
to remove unwantted files and fix registry and windows errors.
Use System Restore: To use System Restore, first restart the computer by pressing[Ctrl][Alt][Delete]. When you see the message Please select
Try holding down the "F-8" key when the emachines logo appears, see if you get a prompt for "safe mode". If you can get the system up and running in safe mode, shut it back down from the start menu. That should rewrite the boot sector and may clear the problem.
These kinds of issues are most often related to driver conflicts. First thing you need to do is reboot your PC while holding F8, until you receive the menu about booting in to Safe Mode. Try booting in to Safe Mode.
If you can get in to Safe Mode, disable any new devices you have recently installed, reboot again, this time letting it try to boot all the way to Windows.
If it reboots again, go back in to Safe Mode and disable/uninstall something else.
Basically, it is a process of elimination. Safe Mode loads a very minimal set of system drivers, so if you can boot in to Safe Mode but not in to full Windows, the problem is one (or more...) of the drivers that load in Windows but don't load in Safe Mode.
you have not set the cdrom as first boot device in the bios (press F2 or Del on boot up to get in bios), choose cd as first boot device, save settings and restart the pc with your cd in the drive and then when prompted press enter
