20 Most Recent eMachines W3507 PC Desktop Questions & Answers
the cable connectors are the same color as the pins were they go.
eMachines W3507 ... | Answered on Feb 13, 2013
Not sure what you truly mean, but you need an install disc. It could be a CD / DVD, USB, or even a hard drive partition.
eMachines W3507 ... | Answered on Dec 28, 2012
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer
If done properly the user should get to a screen similar to the below screen. Select the option for Safe mode command prompt only Windows Advanced Options Menu
Please select an option: Safe Mode
Safe Mode with Networking
Safe Mode with Command Prompt Enable Boot Logging
Enable VGA mode
Last Known Good Configuration (your most recent settings that worked)
Directory Services Restore Mode (Windows domain controllers only)
Debugging Mode Start Windows Normally
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice. To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue.
or
It is possible for the Windows operating system on your eMachines computer to have a critical failure. If the operating system on your eMachines computer is failing, you can use your recovery discs to restore your computer. Recovery discs come with your purchase of an eMachine, and contain your operating system and all your basic drivers. You can recover your eMachines W series in about an hour.
Turn off your computer and press "F8" to enter the BIOS menu. Tab over to the "Boot Sequence" or "Boot Order" menu. Move your optical drive to the top of the list. Press "F11" to exit and save changes. Insert your recovery disc into your optical drive, then restart your computer. Press any key to boot from disc. Select the "Full Recovery" option from your recovery disc menu. Allow the recovery procedure to complete. Hope this helps.
Restart your computer repeatedly tapping the f8 key to enter safe mode while the screen is black once in safe mode where the only things working will be your keyboard and mouse allowing you to attempt to repair your computer. Use the system restore to restore your system to an earlier time click start all programs accessories system tools you should see your system restore option if it is a hardware issue the system restore might not work Manual restore points that you specify with the System. Configuration utility Installation restore points that occur before you install a program or a service you can use the system checkpoints or the installation restore points to restore your computer's settings to a date when it operated correctly. This may also help determine the cause of the configuration error.
Enable VGA mode
Reboot
Return to OS Choices Menu Use the up and down arrow keys to move the highlight to your choice select the safe mode option To perform a system restore, follow these steps: 1.Click Start, click Run, type msconfig, and then click OK. 2.On the General tab, click Launch System Restore. 3.Select Restore my computer to an earlier time, and then click Next. 4.Calendar dates in bold are possible restore points. Click the most recent one to view system restore information. 5.Select a system checkpoint or an installation restore point, and then click Next. 6.Close all other programs. 7.To start the system restore, click Next. 8.Your computer restarts. Repeat steps 1 through 8 until you fix your configuration issue. Hope this helps.
Test your PSU power supply unit or replace it if your power supply units fan is not working your PSU is faulty http://pcsupport.about.com/od/toolsofthetrade/f/powersupplytest.htm One bad lead can cause a computer to continue on a cycle of restarting or to shutdown or fail to detect/ boot up a computer hard drive WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards Test all leads that attach to your hard drive power and data cables IDE SATA the leads from your MOTHERBOARD TO YOUR HARD DRIVE make sure they have a secure dust free connections and are not faulty or just replace them they could be faulty Make sure all leads that are attached to your dvd\cd floppy drives have secure connections and are not faulty or just replace them they could be faulty. Computers need power and data to travel through every working device to continue its cycle and have an end so any faulty leads will end up with a computer error. Even something as small as a faulty electrical or fan lead can cause you problems Motherboard and a Hard Drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail. Check all electrical power input and extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working also check the Cmos battery and computer RAM modules make sure they are securely seated with no dust built up or in the sockets on some motherboards cmos batteries are soldered in. Check you CPU central processing unit make sure its securely seated and has thermal paste it might be getting to hot the thermal paste will help disperse the heat Thermal compound is a sticky paste that is placed directly onto the CPU. http://www.hardwaresecrets.com/article/Thermal-Compound-Roundup-February-2012/1490 Allowing for a more direct heat transfer between the CPU and HEAT SINK and preventing air gaps from forming between the CPU and heat sink. Another possible reason could be a memory dump you might be running to many programs at the one time putting to much strain on the CPU central processing unit. If you can get your computer stable enough scroll to bottom toolbar bottom of screen right click select task manager applications you will see whats running if you see anything you dont need running select end now also under processes see what is ticking over again if you see something you don't need to be running end now or you might uninstall that program and some unnecessary programs not having enough computer ram can cause memory dumps If you are not sure if a module is right for your system use the Crucial Memory Advisor tool for a list of guaranteed compatible modules. first you will need to select the manufacturer from a drop down list then select your product line from a drop down list then select the model then click find it will take you directly to compatible ram also you will have an option to scan your system you should always for a guarantee on any ram modules when purchasing them or buy working pairs if possible. You might have a virus or malware. Download at least one of these of course it will depend on your operating system. http://www.majorgeeks.com/Microsoft_Security_Essentials_for_Windows_d6242.html microsoft security essentials your operating system must be registered Win7/Vista/XP 64 bit http://majorgeeks.com/downloadget.php?id=4281&file=1&evp=dbb3b0aebe6a6a4ff18089a6489a5e62 anti malware free edition Win XP/2003/Vista/Windows7 http://windows.microsoft.com/en-US/windows/products/security-essentials/product-information malware protection http://100-downloads.com/download.php?p=615 windows xp microsoft security essentials http://100-downloads.com/download.php?p=614 windows 7 microsoft security essentials Capacitors look like small metallic canisters and they are found in many different computer components including computer monitors, computer motherboards, video cards, power supplies and a variety of other consumer products. A bad capacitor can cause a variety of computer problems, but if you can identify the faulty capacitor you may be able to replace it and save your computer.
Capacitor
Capacitors, sometimes also called condensers, are used to store energy in an electric field. In the context of computing, capacitors are used to block the direct current being circulated around the motherboard. A typical capacitor should last up to 15 years, but some computer manufacturers use substandard capacitors resulting in shorter lifetimes. Computer Problems b> When a capacitor has gone bad on a computer you may experience a large range of problems. The computer may have trouble booting up, or it may shut down without notice after running for only a short period of time. The most common problems associated with faulty capacitors are that they cause unexpected computer crashes and general reliability issues ranging from read/write issues to distorted screen images. b> Identifying a Bad Capacitor b> To identify a bad capacitor you will need to open your computer case and locate the capacitors on your motherboard. A bad capacitor may exhibit swelling at the top or the base of the capacitor or it may sit at an awkward angle with the motherboard, so compare the various capacitors in your computer in terms of and placement. Additionally, a bad capacitor may have a funny smell or it may have a brownish residue leaking from the top or the base. b> Prevention b> Manufacturers claim that capacitors may go bad because a computer is not receiving enough power from a power supply, because of an overclocked processor or because a computer is operating in an environment with too much heat or humidity. However, some capacitors prematurely fail due to faulty work on the part of the manufacturer. If you have a bad capacitor be sure to do research as to the lifespan of other products made by your manufacturer. Identifying bad capacitors http://www.youtube.com/watch?v=ngA4k32jLGc Capacitor replacement http://www.youtube.com/watch?v=s0Pn2tEjY04 How to check a capacitor http://www.youtube.com/watch?v=U4tnHA0phcc Replacing a leaking capacitor http://www.youtube.com/watch?v=s0Pn2tEjY04 Could be a problem with the Hard Drive or the Hard drives PCB http://www.onepcbsolution.com/ Hope this helps.
Ram modules might be dirty or dirt in ram sockets
Remove the memory modules from their slots.
Take the opportunity to clean the slots on the motherboards and the memory module connectors.
Use compressed air to blow dust away and clean contacts with a soft cloth.
Do not use a metallic vacuum cleaner if it touches any component it may create a short and cause damage to the motherboard or other components.
hope this helps
eMachines W3507 ... | Answered on Nov 05, 2012
Hello you can download the vlc player here:
http://www.videolan.org/vlc/
It does play dvd you can even record a clip of your favorite movie
Click on show and select advanced controls when the program is installed
And here is a free burner:
http://cdburnerxp.se/
I use this codec:
http://www.codecguide.com/
Good luck
eMachines W3507 ... | Answered on Aug 14, 2012
Download the Latest Codec HERE
you will need to open up your network connections
click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red X or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question mark? right click install drivers
the driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc or you might download one if you dont have on a disk
Make sure you Ethernet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabled
hope this helps
eMachines W3507 ... | Answered on Jul 18, 2012
3 bleeps usually relating to memory... try removing and re-inserting RAM and video cards... or try them elsewhere in another machine. It may be wise to remove all the RAMs and add one at a time while trying to reboot.
NOTE: Remove the power wait a few moments before handling each RAM.
Another cause since it's been 'sitting' a while could well be the power supply due to failing capacitors, so trying another wouldn't be a bad idea.
eMachines W3507 ... | Answered on Jul 03, 2012
You may want to try re-doing the driver for the sound card. Sometime when they get removed are you using a PCI card or on-board either way something was lost in the mix of things. You would think just switching the box would not be a big deal when moving parts around to the same places.
You may have used a different PCI port possibly download the driver software again or go online and check updates Windows it may come up with the driver for you. I think you can find that driver Click Here John
eMachines W3507 ... | Answered on Apr 13, 2012
On most PC's, shut down your machine, wait a minute or so, power it back up and start tapping the F8 button until you see the prompt for safe mode.
eMachines W3507 ... | Answered on Mar 22, 2011
Luckily, people who made the DVD and CD drive thought of this. On the drive, underneath where the cd tray comes out is a very small hole, slightly bigger than a pin. When you find it, get a needle, or very pointy small object, and push inside, which should eject the CD tray. You may not hit the button on the first try, slide it in straight, and try again.
eMachines W3507 ... | Answered on Dec 30, 2010
Go into BIOS and click load default settings, then hit F10 to exit and save the settings
eMachines W3507 ... | Answered on Dec 12, 2010
Most of the reasons for automatically shutdown are lack of cleaning or cooling. Clean your computer and put one (1) drop of thermal paste on the cpu core. Also your system files are corrupted or infected by viruses.
Please rate me
eMachines W3507 ... | Answered on Nov 23, 2010
the RAM will max out at 2GB.
It takes 240 pin DDR2 PC2-530 according to my research
eMachines W3507 ... | Answered on Oct 30, 2010
The eMachines W3507 uses an Intel D102GGC2 motherboard.
Yes it does. It's a DB-25 parallel port.
Look at the I/O area on the back of the desktop computer.
(Input/Output)
The Green PS/2 port is for the Mouse. To the right of it is a parallelogram shaped port.
Pink in color, 13 pins across the top, 12 pins across the bottom.
DB-25 parallel port example, (Not pink in color)
http://en.wikipedia.org/wiki/File:Parallel_computer_printer_port.jpg
Intel Support > D102GGC2 Motherboard Manual download page,
http://www.intel.com/support/motherboards/desktop/d102ggc2/sb/CS-022441.htm
Click on the first file listed. English Product Guide [PDF]
(In blue)
This is a PDF file. You may not see anything happening for up to 30 seconds after you click on the file name.
It may also take additional time to fully download.
(Took 4 seconds for the first page to come up just now, and 23 seconds for it to fully download.
Medium speed DSL connection)
Go to Page 11
eMachines W3507 ... | Answered on Oct 22, 2010
Your fan is supposed to run all the time. If it didn't, your computer would overheat and burn itself up.
eMachines W3507 ... | Answered on Aug 26, 2010
eMachines W3507  PC Desktop Logo
Popular Tags
66 questions posted
Top eMachines Computers & Internet Experts
Andrew Chrostek
Andrew Chrostek
Level 1 Expert
Thomas F. Schneider
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
W eMachines
  • W eMachines
Most Popular Question
computer starts shuts down
  • Computers & Internet
