I have a problem my refrigerator door falls off when opened. I had problems with air gap along top of refrig door so i switched the hinges to the other side of the door and voila it was fixed for a year now the door is falling off. I felt the bottom peg and it seems to be moving up and down creating space for it to slide off the hinge. I believe my children hanging on the door has led to this problem. I dont care for the frig got it on clearance. Should I replace frig or replace parts and how?
SOURCE: Refrig door gasket does not prevent gap when door is closed
Lift up the gasket and look for screws securing the gasket to the door.
Loosen all of these screws a few turns and twist the door in the direction needed to seal.
Hold the door in this position as you tighten the screws.
This can be tricky and sometimes requires multiple efforts.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
