20 Most Recent Haier HSB03 Compact Refrigerator Questions & Answers
no 1 setting is close to zero degrees C the setting should be around 4 for normal every day use
call a technician to fix /replace the thermostat
if you continue to use a metal object ( screw driver , knife, fort etc ) when defrosting , you problems with the fridge will soon be over as you will puncture the evaporator section and that is not repairable so you will require a new unit
Haier HSB03... | Answered on Jul 05, 2017
there is a temperature probe that does not connect to anything .should be in the freezer section tho
Haier HSB03... | Answered on Jan 12, 2016
You would need to clean the area around the puncture real well and get some epoxy putty to repair the hole. Allow for the area to dry and harden at least 24 hours.
Then you would need to evacuate the system to make sure no moisture is in the sealed sytem or ice will form in the lines and block the flow of freon. The system will only hold about 1/3rd of a 12 ounce can of R134a which anyone can buy a a automotive arts store. You would need to find a way to tap into the system to charge and vacuum it. The old folks used to purge a system instead of vacuuming it. The newer freon is environmentally safe so no special card is needed to purchase it. However it is still dangerous. You must not breathe the stuff or connect it to the high side of the compressor. The discharge side willl always be the high side and it will always go to the cooling condenser and is small steel line. An ear coming out the compressor is an ideal spot to connect a saddle valve to tap into the system. Before attaching a saddle valve you will fair better if you sand the copper down to prevent leaks. A saddle valve can be purchased at any appliance parts store. Ask for an A-1 line tap. To do the job right you need guages. The low side pressure should not exceed 5 PSI. Thats all the smart pills I have. The gauges will have 3 hoses. Blue(low side)red(high side)yellow(freon). Put your blue hose on the A-1 tap, connect your freon to the yellow hose, and put the red hose on the vacuum pump. Open all the valves on the gauges and turn on the vacuum pump.(Leave the freon closed). After 30 minutes close all valves and shut down vacuum pump. If the vacuum holds, open the freon can and crack open the blue hose, let the freon go in slowly till it equalizes. Bubble test for leaks at the patch. Plug in the ice box and watch the guage drop. The needle on the blue gauge should be close to 5 PSI for a correct charge (over charging will choke down the compressor,not good). Remember the ice box only holds 4 ounces! That is one third of a 12 ounce can. Weigh it in if you want to be exact. Check for leaks. If all goes well it will be good as new.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Haier HSB03... | Answered on Dec 07, 2014
Good day,
No reasonable repair possible. That is a refrigeration line. The repair would exceed the price of a new unit.
Defrosting these machines should be done with a fan only.
To raise the temperature of the refrigerator you set it to a higher number.
Replace the fridge compressor with another one, try a Google search and maybe you'll find result's for your specific fridge. If all else fails, then ring up your fridge manufacturer and talk to them about your fridge, and if you still have warranty and you complain hard enough, they might just send in a new compressor.
Haier HSB03... | Answered on Jun 11, 2014
Haier HSB03 Compact Refrigerator Logo
130 questions posted
Top Haier Refrigerators Experts
geob91
Marvin
Marvin
Vernon Taylor
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
yea mini fridge just
  • Refrigerators
