20 Most Recent Haier HTQ21JAAWW Top Freezer Refrigerator Questions & Answers
Door seal comes loose, shut
Most likely the seal is worn, however have you wiped all the build up of any mold and debris from the seal and frige frame that seal closes to?
Sometimes just a good cleaning with hot water and mild (not harsh sprays) soap like dish soap can bring the cling back.
Otherwise its replace the seal.
If your broke you can latch the door shut by making a Velcro handle on the outside.
12/16/2012 1:56:04 AM • Haier HTQ21JAAWW... • Answered on Dec 16, 2012
Refrigerator door fell off
Get a new fridge, and if the kids swing on this one, threaten to get new kids as well!!!
5/19/2012 9:57:00 PM • Haier HTQ21JAAWW... • Answered on May 19, 2012
The bottom door is not closing. I have pick it up to get it to shut.
change the hingers
3/11/2012 3:42:17 PM • Haier HTQ21JAAWW... • Answered on Mar 11, 2012
Freezer works but the fridge does not
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
9/16/2011 5:49:56 AM • Haier HTQ21JAAWW... • Answered on Sep 16, 2011
My 3yo Haier HTQ21jaaww refrigerator
things to ck . is the compressor running ? remove back the comp will feel hot if running . if its running it may have lost its gas .. / if not running but the cooling fans are . the relay on the compresser may have failed .. hope htis elps mm .. feed back pls ..
7/11/2011 1:15:44 AM • Haier HTQ21JAAWW... • Answered on Jul 11, 2011
I have Haier refrigerator moderl number
Thank you for contacting fixya.com.
Check the coils on the rear of the refrigerator and make sure they are clean and dust free. Also check the back wall or floor of the freezer section for frost. Check the evaporator fan to see if it is running. Check the condenser coils under the unit for blockage from dust. Check the condenser fan under the unit to see if it is running. If you have frost in the freezer there is a problem with the defrost system and the freezer will start to warm eventually as well as the fresh food section. If that is the problem you can check the defrost terminator, defrost heater/s, and the defrost timer or adaptive defrost control If used on your unit or the main control board if so equipped. Also check the freezer to ensure it isn't over loaded with food stuff, reason being air must flow freely threw out the entire refrigerator in order for the thermostat to work correctly.
Defrost the freezer by disconnecting the power to the refrigerator and letting it sit for at least 24 hours with both the doors open to allow the frost to melt completely but it will build up again in 1-2 weeks and start the warming up again.
Please get back to us if you have further query else please accept the suggestion.
6/1/2011 3:31:50 PM • Haier HTQ21JAAWW... • Answered on Jun 01, 2011
0answers
The whole fridge is not cooling. what are the
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
10/13/2010 9:14:12 PM • Haier HTQ21JAAWW... • Answered on Oct 13, 2010
Frost builds up on freezer walls. I have
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
Water Running in efrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
8/18/2010 4:48:17 PM • Haier HTQ21JAAWW... • Answered on Aug 18, 2010
Haier refrigerator is not cooling and compressor
If the compressor has a relay chances are it is toast. If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
6/4/2010 6:22:02 PM • Haier HTQ21JAAWW... • Answered on Jun 04, 2010
2answers
The freezer frosts and ices up
Hello and Welcome to Fixya,
This is one of the most common problems in most of the refrigeration appliances. What’s going on here is that the condensate drain hole in the freezer gets plugged with ice. Once this happens, all the frost melted off the evaporator during subsequent defrost cycles can no longer drain and so spreads out on the freezer and dribbles down and also chokes other components. Here are the instructions that you need to follow inorder to get rid of the problem:
  • Unplug the refrigerator and pull everything outta the freezer, and I mean everything.
  • Remove the bottom panel inside the freezer so you can see the condensate trough in the back of the freezer.
  • Notice that the condensate trough is filled with ice– all that has to be cleared out.
  • Take it easy back there, delicate parts are exposed– don’t start hacking at it with an ice pick because there are chances that you’ll just end up puncturing the evaporator and you’ll turn a simple, inexpensive repair into a majorly expensive one.
  • Use hot water to drain all the frosted ice that is visible.
  • Re-place all the units removed during the process.
  • Once all the ice is cleared away and the condensate drain opening is cleared, you are done.
Best of Luck,
Please do rate my solution, If found helpful.
Regards.
2/10/2010 11:29:03 PM • Haier HTQ21JAAWW... • Answered on Feb 10, 2010
Haier HTQ21JAAWW Top Freezer Refrigerator Logo
39 questions posted
Top Haier Refrigerators Experts
ADMIN Andrew
ADMIN Andrew
vince
Are you a Haier Refrigerator Expert? Answer questions, earn points and help others
View Most Popular
Haier Refrigerators
  • Haier Refrigerators
Most Popular Question
3yo haier htq21jaaww refrigerator
  • Refrigerators
