SOURCE: 2001 Mercury Grand Marquis brake and ABS dash lights on and off
The red brake light is the key here. That usually indicateds a hydraulic problem. Check you fluid level in master cylinder and see if it is low. Also the level indicator sensor there in the master cylinder maybe sticking or corrioded. If ABS sees the red brake light it will shut off and turn on the ABS light,also traction control would be disabled as well.
SOURCE: I own a 2004 Mercury Mountaineer, and the ABS
On a Car like that you have little sensors on each one of the wheels. These sensors are small, delicate and finicky. You probably have a loose one or when the wheel heats up or reaches a certain speed, highway driving, it loses the connection and the light comes on.
The best way to fix this is go to a shop. Since the answer lies in the computer somewhere they need to check it. Note that the computer on your car stores the data when this happens and they should download the stored data if everything " seems fine ". Hope that helps
SOURCE: I have head and brake light but no tail and dash board light
I have a 1993 grand marquis n all my lights come except the taillights no blown bulbs check all d fuses no bad ones can I just get a good answer to my problem
Also when it is warmed up it will stay on longer.
