SOURCE: Incompatable Ink Cartridge HP C4480
Cartridge failed try another new one.
Yea it is new and should be good but they are machines and are prone to failure too.
SOURCE: My printer keeps displaying the message ink
HI,
ITS PROBLEM WITH CATRIDGE CIRCUIT,REMOVE THE ERROR CATRIDGE ,TURN IT BACK,CLEAN CIRCUIT WITH ISOPROPHYLE.
TNKS
RABBANEES
SOURCE: Ink Cartridge error messages
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
Don
SOURCE: printer giving 'incompatible ink cartridge' message
replace your cartridge with a new one or refill others old
check here how you can do it your self
You-Tube video "sOriLrbuBao" placeholder (do not delete)
You-Tube video "II9gpIXs_lE&feature=related" placeholder (do not delete)
SOURCE: incompatible ink cartridge but I'm using HP
There are different ink cartridges for each HP printer. Make sure you are using the correct one by looking at an old ink cartridge. If this is not the issue, you should try updating the drivers for your printer, which you can do by downloading them here:
http://h10025.www1.hp.com/ewfrf/wc/product?cc=us&lc=en&dlc=en&product=3418705
If that doesn't work, you may need to call technical support.
Please leave positive feedback for me, and good luck to you!
These types of severe
cartridge errors (i.e. "refer to documentation" / "incompatible cartridges", "print
cartridge(s) problem", etc.) typically indicates the internal micro-electronics
of the HP #74 / 75 (or 74XL/75XL) cartridge(s) are damaged. The cartridge's electrical wire runs at
rear and lower side of the ink cartridge, are very delicate and are somewhat
susceptible to ink attack over time, which can lead to premature failures. In
addition, the older the cartridge the higher the chance of an internal
electrical failure. I suggest you first run a 'Tap 41' diagnostic test to
check cartridges electrical health (this is a forced test); you may also bypass
the error (temporarily) on most models which use HP 74/75 cartridges. Refer to
Inkjet411 youtube videos below:
HP 74, 75, 74XL, 75XL
Cartridges - Solving Errors & Warnings: http://www.youtube.com/watch?v=C5ISTGyScWU
HP Photosmart
C4200-C4500 and C5200-C5500a Printers -
Diagnostic Tap 41 Test: (verifies
electrical health of ink cartridges):
http://www.youtube.com/watch?v=8fE-IM4AVMc
HP Photosmart 4200-4500 5200-5500 Printers -Cartridge Error Bypass (HP
74-75 Cartridges):
http://www.youtube.com/watch?v=UDxRkAGOJaI
HP Officejet
J5700/J6400 Printers -Cartridge Error Bypass (HP 74-75 Cartridges):
http://www.youtube.com/watch?v=3X3_D90SSq4
Ink
Refilling & Cartridge Care Tips - Everything you need to know: http://www.youtube.com/watch?v=FnXoDIblpdU
