20 Most Recent HP Office Jet 4500 G510n Questions & Answers
Reset ink level on hp 4500 printer
You do not need to reset ink level ! Look at this pic,I never replaced cartridges. Solved very fast. reset-ink-level-hp-4500-printer-h4ksqymctpeza4hutjcwmwuv-4-0.jpg
1/25/2016 1:36:59 PM • HP Office Jet... • Answered on Jan 25, 2016
How to delete former owners wireless data on HP 4500 - G510n wireless printer.
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the initialization
3/26/2015 9:16:13 PM • HP Office Jet... • Answered on Mar 26, 2015
I have a 4500 office jet and the paper is severly jammed. can the printer be taken apart to fix this problem
Yes; there is a great (official HP !) video tutorial on how to take it apart properly here:
7/17/2014 2:51:18 PM • HP Office Jet... • Answered on Jul 17, 2014
0answers
Rail banging
Be the first to answer 2/15/2014 3:17:09 AM • HP Office Jet... • Posted on Feb 15, 2014Be the first to answer
Not detecting paper on top of the glass
if you are trying to scan/copy a receipt of something else that is smaller, try to tape it to a regular sheet of paper before you copy it. then the unit can detect the paper size.
1/2/2014 9:26:22 PM • HP Office Jet... • Answered on Jan 02, 2014
Black Will Not Print
I installed new ink cartridges but after installation my printer don't align when making copies on top of the glass the paper is not detected.
1/2/2014 9:11:54 PM • HP Office Jet... • Answered on Jan 02, 2014
Problem with my printer
When you reboot your machine the print spooler service should restart on its own. If this does not solve the problem you can go to the services panel and manually restart the service:Start > Run > type services.msc > Hit Enter > Scroll down to Print Spooler > Right click the service and hit restartThe above solution will only allow you to do this if you are an administrator on your machine.
2/20/2013 6:02:57 PM • HP Office Jet... • Answered on Feb 20, 2013
Hp officejet4500status says printing but not printing
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles. If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive. It may be more cost effective to buy a later model and better printer than replace the print head.
1/18/2013 3:42:29 AM • HP Office Jet... • Answered on Jan 18, 2013
I have a hp 4500 all in one printer but i cant install it because i dont have the drive or cd , what else can i use
You can download the HP printer drivers from their supportWEB site. Please click on this link and select your model printer to download:-http://welcome.hp.com/country/us/en/support.html
4/28/2012 10:44:23 AM • HP Office Jet... • Answered on Apr 28, 2012
Need to down load printer information
HP's home page for the product is here.
3/14/2012 4:46:03 PM • HP Office Jet... • Answered on Mar 14, 2012
Incompatible ink cartridge ho 4500
I have had simlar problems with other brand inks on epson printer a guy in a computer shop were I bought the ink from told me to take the ink out wipe the chip with a clean cloth wipe in one direction, also your ink when new has a piece of thin plastic that now has a small hole in it as you have taken it out from printer put a small piece of sellotape over hole other wise printer will think you are putting old cartridge in again you might need to do this a few times, but bear in mind that this was done with an epson printer but it doe's solve the problem when it crops up from time to time.
2/25/2012 4:56:07 PM • HP Office Jet... • Answered on Feb 25, 2012
Office jet 4500 smudges
HiYou may need to do a maintenance check on your printer.Go to control panel and click on printers and scanners..There should be an option to do a clean...If you do a roller and nozzle check this should stop the smudgingHope this helpsKind regardsMichelle
2/23/2012 5:19:58 PM • HP Office Jet... • Answered on Feb 23, 2012
Printer will not print from
Are you using Internet Explorer to print your e-mail or do you use a different browser?
If you are using Internet explorer. try to run the Internet Explorer in administrator mode and verify if you are able to print.
To run Internet Explorer as administrator, follow the steps below:
1. Click on Start.
2. Click on All Programs.
3. Right click on Internet explorer and click on run as administrator.
Also try to turn off protected mode and verify if you are able to print from Internet explorer.
To turn off Protected mode follow the steps below:
1. Open Internet Explorer 7.
2. From the Internet Explorer 7 command bar, choose Tools and then Internet Options.
3. In the Internet Options window, click on the Security tab.
4. Below the Security level for this zone area, and directly above the Custom level and Default level buttons, uncheck the Enable Protected Mode checkbox.
Note: Disabling Protected Mode requires a restart of Internet Explorer 7, as you may have seen next to the checkbox in this step.
5. Click OK on the Internet Options window.
6. If you're prompted with a Warning! dialog box, advising that The current security settings will put your computer at risk., click the OK button.
7. Close Internet Explorer 7 (or later version) and then open it up again.
8. Try again to visit the web sites that were causing your problems to see if resetting the Internet Explorer 7 security settings on your computer helped.
9/12/2011 8:25:24 PM • HP Office Jet... • Answered on Sep 12, 2011
3answers
My hp deskjet 2300 printer is not printing. its says in the desktop it is printing
  1. Click and select. (Settings) > Devices > Printers & scanners.
  2. Select your product and click Manage.
  3. Click Printer properties.
  4. Select the Ports tab.
  5. Select the Enable bidirectional support checkbox and click OK.
Or else google for troubleshooting.
4/20/2024 11:06:50 AM • HP Office... • Answered on Apr 20, 2024
HP Office Jet 4500 G510n Logo
29 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
  • HP Office Equipment & Supplies
Most Popular Question
delete former owners wireless data hp
  • Office Equipment & Supplies
