you should check on your battery cables,chasis cables, and engine bay cables related to your ground or bad connection in between connectors, terminals or hubs.
most of the time its the crank sensor doing this. it will die then restart after about 15 to 20 minutes, when it cools down,until it dies again. the crank sensor sends a signal from the crankshaft to pcm. to tell its the right timing, if bad timing will be way off. and engine will die out. good-day !!
