20 Most Recent Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator Questions & Answers
3answers
I have a generac ix
You engine has a low oil level sensor. If the oil level is low or..... the sensor is bad it will ground the ignition from the coil with the engine switch on. For troubleshooing only disconnect ONE wire from the sensor AFTER you make sure the engine oil level is properly serviced. Then check for spark.
If this does not correct the problem just respond and I will help you.
Thanks for choosing FixYa,
Kelly
10/12/2023 6:11:17 PM • Generac Power... • Answered on Oct 12, 2023
0answers
Why isn't it producing rated output?
Rated output is at full load. Units will produce power up to that limit and use gas accordingly. Very lite load = less output and less gas consumption, etc.
8/30/2015 11:02:44 AM • Generac Power... • Answered on Aug 30, 2015
How can I get the over load light off no power?
Contact the Generac repair/service foks at:
11/7/2014 4:33:16 AM • Generac Power... • Answered on Nov 07, 2014
0answers
Generac ix 2000 does not start. checked spark plug and it is good. oil good.
what a **** generator, worked for 100 hours and now wont start anymore.did all the checks and replacing of spark plug and oil etc, simply wont start, ****, ****, ****..... service is horrible too. they just give you the runaround.
11/5/2012 3:27:54 PM • Generac Power... • Answered on Nov 05, 2012
0answers
2answers
Wiring error code 2099
This 2099 has disabled my Generac after being fine for 2 yrs???
8/7/2018 1:44:02 PM • Generac Power... • Answered on Aug 07, 2018
Generac model 43901 makes a buzzing noise when trying to turnover
I had a similar problem and it was because I had OVERFILLED the oil! I drained enough to make sure it was within the crosshatched markings on the dipstick and it started right up.
7/14/2018 8:37:40 PM • Generac Power... • Answered on Jul 14, 2018
My generac 12000 watt generator has no spark,i replaced the plugs but still none,any advice would be great.
It sounds like the coil has went bad, replace the coil and you should be good to go
10/7/2014 5:47:19 PM • Generac Power... • Answered on Oct 07, 2014
Generac 5793 Ix 2000 surging
It sounds as though there is an issue with the carburetor. If the unit is "surging" with no load I would recommend thoroughly cleaning the carb. It would also be a good idea to test the fuel pump. Per Generac you need to disconnect the fuel line leading to the carb and pull the starter rope over to see if adequate fuel is flowing. If none of this is the issue try testing the stepper motor on top of the carb. If you unclip the wire and use an OHM meter all wires should test at 150 ohms. to test place on test lead on the blue wire and move the other lead to the remaining four wires. The should all ohm out to roughly 150ohms. if this is not the case you need to replace the stepper motor.... Before you do any of this you should check for fresh fuel, a good spark plug, and proper compression.
3/19/2014 7:47:50 PM • Generac Power... • Answered on Mar 19, 2014
Generac Power Systems Generac 5793 Ix 2000 Watt Portable Inverter Generator Logo
21 questions posted
Top Generac Power Systems Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Generac Power Systems Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Generac Power Systems Electrical Supplies
Most Popular Question
generac ix 2000 not start checked spark
  • Electrical Supplies
