It was all fine on friday. ran no probs today just wont start full with fuel.
Is the ignition switch turned to "ON" . Is it full of oil?
The engine can not start mainly due to two problem, fuel system problem and igntion system problem. You need to check for spark and also check the carb and fuel system.
See the link below for detail
http://solosmallengine.blogspot.com/
SOURCE: I have a small Honda
Make sure the fuel valve is on, if that does not fix it you will need to drain the bowl on the bottom of the carb. What model is it
