20 Most Recent Master Heaters MASTER HONDA POWERED GENERATOR Circuit breakers-2500 rated watts 120 VAC/20 Questions & Answers
3answers
My honda gx160 generator keeps cutting out after 2 mins
Sounds like fuel flow is restricted.
Is the vent cap on the gas tank clear?
Pull the fuel hose off at the carb and let run into a container from the tank......is fuel flow good while filling a cup or two worth of fuel?
If not check filter at fuel switch or at hose connection at tank for restriction.
It takes about 2 minutes to use up fuel in the carb with engine running.
Sure sounds like a fuel problem.
1/26/2011 9:52:28 AM • Master Heaters... • Answered on Jan 26, 2011
Honda ex 650 genorator carburetor not getting any
check the fuel filter and the fuel shut off to see if they are clogged
6/29/2010 10:50:11 AM • Master Heaters... • Answered on Jun 29, 2010
Hi . My pull cord has just snapped. I plan to
You have to wind the coiled spring thing before you connect the new rope to it so that it will rewind when you're cranking. It can be tricky and an extra pair of hands will come in handy. Remove the engine cover and turn it over to access the rewind mechanism.
4/6/2010 8:07:47 PM • Master Heaters... • Answered on Apr 06, 2010
2answers
My generator will start for a second or 2 then
Check spark plug / replace
Do not use old fuel / more than 4-6 weeks old
Ensure consistant spark
1/26/2010 7:37:13 PM • Master Heaters... • Answered on Jan 26, 2010
I have a Honda GX160. It starts up first pull,
It sounds like your carb might have some tarnish built up in it and the jets inside the carburetor are not letting enough fuel through. This is really common among generators and lawnmowers because they sit for so long unused. So what happens is, with the choke "on" you are reducing the amount of air allowed into the fuel/air mixture. As you move the choke to the "off" position, you are allowing more air into the fuel/air mixture but not enough fuel is not being allowed in the mixture so it runs too lean and stalls out. Also, don't use tools to clean the carb jets, they are usually made out of brass and a tool can scar the inside of them and create resistance for the fuel flow. Hope this helps!
11/5/2009 2:24:19 AM • Master Heaters... • Answered on Nov 05, 2009
Honda GX160 runs fine for 5 minutes then dies like out of fuel.
I would look for the fuel filter. Blow it our. I know you have a new tank of gas, but you might want to empty it out and make sure the clean and put in new. Even with Stabil in the gas you might just have to much condensation in the tank
9/8/2009 7:46:12 PM • Master Heaters... • Answered on Sep 08, 2009
1995 blazer
I am just a backyard mechanic but since the code says #5 misfire detected, and you've changed the plug, wire, rotor, and cap; something that is possible, besides a computer or sensor problem, is the a piece of carbon is coming loose and is heating up and the sensor is picking this up as the spark. Don't know how to test anything else. Maybe this will help reed
1/16/2009 7:11:51 AM • Master Heaters... • Answered on Jan 16, 2009
Manual for scorpion sl2800 generator
Yes
4/9/2024 2:32:16 AM • Electrical... • Answered on Apr 09, 2024
2answers
My conlog meter is showing the rfcon error please what do I do
No connecting to your utilty company in South Africa. Just FYI, we are a North American site and my not always have the answer, in this case we do Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error-cant-do-anything-on-the-gadget-please-help-on-how-to-re/962048393965724/ Quoting from link above: "Conlog Hi Ola-daniels, Please see below steps to assist with RFCON error : * Press the Back arrow on the keypad - this step is to refresh the UIU ( the device) * Type # 75 # - this is to check the signal strength If it does not go back to the normal display *Type # 80 # - this is to refresh the meter Then lastly you can repair the meter and the UIU by # 36 # The above steps will work better if you are outside the house because the meters uses the radio frequency connection The above error will occur in instances of bad weather conditions or if there is load shedding or power failure If the problem persists after trying the above you may contact the municipality or the service provider."
SOLVED: How do I clear up the rf con error on my meter ...
https://www.fixya.com > ... > The
May 7, 2020 - How do I clear up the rf con error on my meter because I want to ... Https://www.facebook.com/ConlogSolutions/posts/im-having-a-rf-con-error- ... Hi Ola-daniels, Please see below steps to assist with RFCON error : ... shut down the energy alimentation for 2 minute ,but if the defect persist error it show again. SOLVED: Pole meter conlog rf con meter keep on freezing ... Jan. 10, 2017 Meter reading shows rF CON instead of units available - Fixya Jun. 24, 2018 SOLVED: Good day my conlog ip54 elecricity meter showd ... Oct. 6, 2018 SOLVED: Rf con error - Fixya Jun. 20, 2020 More results from www.fixya.com
Please Help With My Conlog Prepaid Meter - Technology ...
https://www.nairaland.com > please-conlog-prepaid-meter
Aug. 6, 2020 - ystar: If the conlog meter is showing rf-Con, it means power supply doesn't reach the meter at all its either Loss of phase from the transformer or a loose contact ... How Do I Load The Activation Token On My Conlog Prepaid ... Mar. 17, 2020 I Need A Technician To Fix This... - Nairaland / General - Nigeria Jul. 22, 2019 I Need Number Codes To Reset Memmcol Prepaid Meter ... Jan. 11, 2019 More results from www.nairaland.com
3/24/2024 3:42:46 AM • Electrical... • Answered on Mar 24, 2024
Wiring 3 lights 3 separate switches
Consult a qualified electrician.
3/23/2024 7:13:23 AM • Electrical... • Answered on Mar 23, 2024
Kawasaki GA1400A Generator. It starts fine, 12 volts okay, but no 230 volts.
Question edited for clarity. Question moved from Motorcycles to Generators category. Some help in the link, but not as much as I would like https://www.google.com/search?q=Kawasaki+GA1400A+no+230+volts+output ..
2/11/2024 5:52:06 AM • Electrical... • Answered on Feb 11, 2024
GE outdoor 200A fusible disconnect can not stay on position, how to fix this issue
It has a cantilever snap action. Either the spring has detached, broken, disabled or unit is otherwise damaged. Heat, water, rodent, etc damage. Replacing the unit is most likely your only option.
2/9/2024 12:37:45 PM • Electrical... • Answered on Feb 09, 2024
What are the valve specs for a kubota av3800 generator
I want PDF AV 3800 Generator
2/8/2024 2:59:27 AM • Electrical... • Answered on Feb 08, 2024
Master Heaters MASTER HONDA POWERED GENERATOR Circuit breakers-2500 rated watts 120 VAC/20 Logo
13 questions posted
Top Master Heaters Electrical Supplies Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Master Heaters Electrical Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Master Heaters Electrical Supplies
Most Popular Question
r nmy pull cord just snapped plan
  • Electrical Supplies
