20 Most Recent Honda Pressure Washer PSI 3000 Questions & Answers
hi there sal rick85
sounds like the unloader valve is not working or stuck closed , check the setting of the unloader valve may be set too high, the unloader must open in odrder to cycle water back to inlet side of pump - if not builds up heaps of pressure , stalls the engine - service the un loader valves on the pressure head
take look and let me know - what brand your blaster unit is i know its honda but what pump
comet - axd, lw/zw, - in line or axial cam
in the mean time here is good web site on power washers
http://www.the-power-washer-advisor.com/
or go to
http://www.the-power-washer-advisor.com/pressure-washer-pump-trouble-shooting.html
cheers pauly46
Honda Pressure... | Answered on Apr 19, 2019
contract honda repair shop
Honda Pressure... | Answered on Feb 26, 2018
How about the carburetor? Did you get all the kero out of there and clean out carb?????????
Honda Pressure... | Answered on Sep 21, 2017
talk with a honda service shop
i suspect that it is a water drain tube to remove water from the bowl of the carby
Honda Pressure... | Answered on Aug 20, 2016
The type of oil recommended for that engine is SAE 10W-30 and the capacity is 0.61 quarts. This and more can be referenced at the website at the end of this solution. I was able to find the owners manual of your particular engine.
http://www.northerntool.com/downloads/manuals/60594.pdf?cm_re=Product%20Page-_-Manual-_-Side
Honda Pressure... | Answered on May 25, 2016
The only way to get down to the bottom of this is to get yourself the necessary fittings and high pressure gauge so you can read what the line pressure is while the trigger is released and applied.
You have to get down to the source, find out what it is.
Could be a bad pump, bypass valve, debris inside trigger, or spray tip is worn out or is too big for the unit it has been attached too (not enough GPM).
Honda Pressure... | Answered on Jun 23, 2015
Your choke controls the mixture of fuel and air. An engine will run rich if it has a restriction to air flow. Try removing the air cleaner, if after this you can turn off the chock you have a dirty air cleaner.
Honda Pressure... | Answered on May 01, 2015
If you are using a water tank for water supply, remove the water supply line from the pressure washer and connect a water hose from a faucet. Turn the water on, then crank the engine. Pull the trigger of the spray gun until water comes out. When then water starts to spray properly the release the trigger, shut engine down with pressure on the line then reconnect the water supply from the tank to the pressure washer. If this fixes the problem then the problem was "air-locked"! Happens alot with new pressure washers that have never been run. If you need any other help, please email me @ davidandlisacampbell@yahoo.com
Honda Pressure... | Answered on Apr 09, 2015
No, but it sounds if the carb needs to be cleaned! Fresh fuel helps too. Check the spark plug and check the breather filter. Also you can crank the engine with the breather filter off and try to move the choke to run then. If it runs with the filter off then there is your problem! 1 question, has anyone try to work on it or adjust the carb in any way?
Honda Pressure... | Answered on Jan 15, 2015
Sounds like the unloader (regulator). Try removing the nozzle, the pull the trigger with the engine running. If motor is still running then it could be the Unloader malfunctioning. If you require a new one try a bypass system for the unloader. The bypass will help save the life of the unloader.
Honda Pressure... | Answered on Sep 25, 2014
Turbo heads are pressure rated for different pressure washers, your turbo head is most likely rated bellow the maximum pressure of your washer which in turn causes a pressure build up in the hose and it's eventual failure.
carburetor needs cleaning/rebuilding/replacing
Honda Pressure... | Answered on Aug 24, 2014
sounds like your pump or motor seized from overheating which makes parts swell / grow in size/expand so they stop working ,,,letting cold water flow through the pump would have cooled the parts and help shrink the parts again .. Overheating can do permanent damage to your machine.. I think it needs to be dismantled and inspected for damage by someone who knows what to look for. not sure if the problem is in the pump or the motor, hope that helped.....pete
Honda Pressure... | Answered on Jul 31, 2014
Honda Pressure Washer PSI 3000 Logo
307 questions posted
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Marvin
Marvin
Are you a Honda Garden Expert? Answer questions, earn points and help others
View Most Popular
Honda Garden
  • Honda Garden
Most Popular Question
honda gc160 pressure washer carburetor
  • Garden
