HP Photosmart C4280 Aio Printer Logo
Carol Ann Boyd Posted on Apr 22, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When I press the scan button it says that the USB isn't connected, but it is connected!
Ali Haider Saleem
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 66 Answers
  • Posted on Apr 22, 2012
 Ali Haider Saleem
Expert
Level 2:
New Friend:
Cheetah:
Answers
66
Questions
Helped
15069
Points
131
Salam,dear, firstly check that whether the usb ports are disabled or not! if disable, then enable them.check for the drivers for usb.check this online help.you can check this also..www.vet-clinics.blogspot.com
1 Related Answer
puertobori
  • 7733 Answers
  • Posted on Oct 31, 2010
SOURCE: want to use printer to scan document to my
USB/PARALLEL CONNECTION USERS:
The Check Cable message generally indicates that there is a communication or connection loss between the computer and the Brother Machine. To resolve this issue perform the following steps:
PART 1: VERIFY THE CABLE CONNECTION
1. Verify that you are using the proper interface cable with your Brother machine. Brother recommends you use an interface cable that is 6 feet (2 meters) or less, directly connected from the Brother machine to an available port on your computer.
a) For USB cable users, a type A/B 1.1 or 2.0 USB cable is recommended.
b) For parallel cable users a Shielded IEEE 1284 compliant cable is recommended.
c) Other cable configurations may work, however connection loss is common. For troubleshooting purposes, do not connect your interface cable through any hubs, splitters, docking stations, or other pass-through devices.
2. Check the cable connection to the brother machine. Remove the cablefrom both the computer and the Brother machine. Leave them unplugged for a few seconds, and then reseat the cable on both ends to ensure a secure connection. For USB users, ensure the USB cable is plugged into the Brother machine's USB Port, not the LAN port if applicable.
3. Restart the Brother machine. Cycle the power off for 15 seconds, and then back on.
PART 2: VERIFY THE DRIVERS ARE INSTALLED
1. Open the Scanners and Cameras Control Panel: Click START -> (SETTINGS) -> CONTROL PANEL -> SCANNERS AND CAMERAS (Note: You may first have to click on PRINTERS AND OTHER HARDWARE or HARDWARE AND SOUND)
2. Verify that the Brother scanner is listed. If the Brother scanner is listed, continue to PART 3. If the Brother scanner is not listed, continue to PART 6 to install the driver.
PART 3: RESTART THE WINDOWS IMAGE ACQUISITION (WIA) SERVICE (WINDOWS XP/VISTA USERS ONLY)
1. On the computer, Click on START -> RUN or in the START SEARCH line.
2. Type: SERVICES.MSC and press ENTER.
3. Locate WINDOWS IMAGE ACQUISITION (WIA) Service, and double click on it.
3a. If you are not able to locate the service, this indicates and operating system issue. This service exists on all Windows XP/Vista computers. Contact your computer OEM for further support.
4. Check the STARTUP TYPE, and make sure it is set to AUTOMATIC. If itis set to anything else change it to AUTOMATIC.
5. Verify the Service Status.
a) If the Service is STARTED, press STOP, and then press START to restart the service.
b) If the Service is STOPPED press START to restart the service.
*Note: If you receive any error message while restarting the service, orare not able to start the service this indicates an operating system issue. This service controls all scanning operations. If the WIA Service is not started, you will not be able to scan from any scanner, and refer to the Computer OEM for further support.
6. Close WINDOWS IMAGE ACQUISITION (WIA) Service, and close the Services window.
7. Attempt another test scan using the SCAN button on the Brother machine. If the scan is unsuccessful, continue to PART 5.
PART 5 - APPLY THE SCANNER PATCH BrWIARegRepair.exe (WINDOWS XP/VISTA USERS ONLY)
1. While connected to the Internet, on your computer, Click on START -> RUN
2. Erase anything in the open box and type: http://209.215.81.199/download/mfc/BrWIARegRepair.exe
3. Click OK
4. Click SAVE. For the Save-In location choose DESKTOP and click SAVE again. This will save the file to the Desktop.
*NOTE: If DOWNLOAD COMPLETE appears, click CLOSE
5. Go to the Desktop and locate the zip file BrWIARegRepair
6. Click UNZIP. You will receive a message stating: 1 file unzipped successfully. Click OK and close the WinZip Self Extractor window. Thefile will automatically be extracted to a Brother folder on the desktop.
7. Go to the Desktop and locate a Brother folder. Double click the Brother folder and then double click the BrWIARegRepair.exe file in the folder.
8. When you see the following message: SETUP COMPLETED PLEASE CLICK OKAND THEN RESTART WINDOWS FOR THESE SETTINGS TO TAKE EFFECT. Code X. (NOTE: X will be 1, 2, or 3). Make a note of the code and restart your computer.
9. Once the computer restarts attempt another test scan using the SCAN button on the Brother machine. If the scan is unsuccessful, continue toPART 6.
PART 6: UNINSTALL AND REINSTALL THE BROTHER DRIVERS
Before you perform the uninstall, ensure that you have the software CD or access to the Internet to download the software needed to reinstall.
1. On the computer click on START -> (ALL) PROGRAMS -> BROTHER -> MFL-PRO SUITE -> UNINSTALL. If the software is not present continue to step 4.
2. When asked to confirm that you want to completely remove the software, click OK.
3. When the uninstall is complete, you will be prompted to restart the computer. Click YES.
4. Once the computer restarts, reinstall the software. For instructions, refer to the solution: How do I setup/install my Brother machine with a local (USB/Parallel) connection? #OR- How do I download and install my Brother machine using a local (USB/Parallel) connection?
5. Once the software has been reinstalled, attempt another test scan using the SCAN button on the Brother machine. All drivers have been reinstalled, and the issue should be resolved.
6helpful
3answers
HP 2520hc scanner drivers
Which driver set did you install? Did you install the HP basic drivers, the full software or the Windows XP built-in driver? The Windows OS driver usually only is the printer driver.
If you connected the USB cable before installing the HP software, you will get the OS drivers. Disconnect the USB cable and then uninstall the printer driver. (Start > Control Panel > Printers and Devices. Then right click on the printer and select Remove Device.)
Install the HP software. If you want to launch a scan from the all-in-one's front panel button, install the full software.
Next open the scan software on your computer. (This is the HP Solutions Center for most models if you use the full software.) Attempt to launch a scan from the software. Adjust the resolution and other settings as needed. Then use those settings to adjust the destinations for the front panel buttons in the software. (Settings > Scan Settings > Button Settings)
If this doesn't work, try a different USB cable, a different USB port on your computer and a direct connection (if you are using a USB hub). Scanners require bi-directional communication with the computer and may fail when the printer works due to a minor cable issue. If you have the printer connected to a router or similar device to turn it into a network printer, again the scanner will not work. Again the direct connection to the computer is needed.
If you are still having trouble, can you use the all-in-one's copy function? If not, do you have any error messages? If the scanner mechanism isn't moving, the unit probably needs service. (This model doesn't have a scanner lock to protect the mechanism in transit.)
I hope this helps.
1helpful
My philips gogear vibe wont turn on
Reset your GoGear with something sharp like the tip of a pen or the end of a paper clip,
if you're device isn't working properly or there's a frozen display.
Insert the sharp object into the "Reset" hole (located at the bottom of the player), and hold it there until the device turns off.
If resetting the device does nothing to restore the display, access the "Philips Device Manager" through your computer to recover the GoGear.
Click "Start" on your computer, then "Programs," "Philips Digital Audio Player," "Aria Device Manager," and then "Philips Device Manager."
This will launch the "Philips Device Manager." Make sure the GoGear is turned off completely. Connect your GoGear to your computer while holding down the "Volume Up" button.
Continue to hold the "Volume Up" button on your GoGear, until the "Philips Device Manager" recognizes the device and enters recovery mode.
Click the "Repair" button when it appears on your computer, then folow the steps to fully recover the GoGear.
Properly disconnect your GoGear from your computer and restart the device.
Recharge your device if your GoGear dies suddenly while playing.
Connect the GoGear to your computer via the supplied USB cord.
Plug one end of the USB cord into a functional, open USB port on your computer. Plug the free, smaller end of the USB cord firmly into the small USB jack on your GoGear and turn your computer on.
This will begin the charging process of your GoGear.
If recharging doesn't work, the battery may need to be replaced.
Check that your GoGear isn't in standby mode. Hold the "Power" button for two seconds to turn it back on.
hope this helps
I can copy but can't scan
What OS does your computer have? Can you launch a scan from your computer (not the buttons on the all-in-one)? (This will work if the scanner driver is installed.) You should always do this at least once. How is the scanner connected to the computer? You may want to try a new USB cable and a different USB port. (Scanning requires bi-directional communication with the computer. Thus long USB cables and USB hubs may not work when scanning.)
To launch a scan from the scanner, make sure that you have the MP Navigator software installed. It is available here: http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp450#DriversAndSoftware . This software includes a monitoring program that "listens" for the button press. Depending on your OS, a button press should launch a query for the desired action. In some cases, you may need to set up the buttons in the Canon Scan Gear software first. (Launch MP Navigator and then look for the Setup menus.)
I hope this helps.
(note: make sure that the software is set to save the scan to a location that your current user account has write permission. I've hit this after moving to a new machine; some folders were locked after using the Transfer software.)
I am having problems making my scanner work - I can't scan a document from the printer/scanner/fax/copier to my laptop
How is the all-in-one connected to your computer? What OS are you using? Did you install the full software, basic drivers or the OS drivers? Are you starting your scan from the computer or the buttons on the all-in-one? Is this a newly installed printer or one that has been used several times with this computer?
The Photosmart C7180 can be used with a USB connection, wired ethernet network, wireless network, bluetooth or PictBridge. For a Mac OS, only the USB connection will work.
If you need the drivers, see http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?cc=us&dlc=en&lc=en&product=1153754& and select your OS.
If you connected the all-in-one to the computer via a USB connection before installing the software, you may have an OS driver that does not include the scanner driver. Disconnect the USB cable then uninstall the driver. Then install the HP driver. If you do not install the full software, you will not be able to use the buttons on the scanner to launch a scan. You'll have to start the scan from the computer.
If you have the full software, the HP Solution Center is installed. This includes a monitoring program that should run when you start your computer. This listens for the press of a button on the scanner and launches the appropriate part of the HP software. However, you need to set the button destinations in this software first. I recommend manually scanning at least once to set the appropriate resolution and destination folder for your scans. Then in the Solution Center, click Settings, Scan Settings, Button Settings and then Front Panel Scan Buttons. Set these based on your default settings.
If this all-in-one has been working previously, check your connection. Scanning requires bi-directional communication with the computer and can fail even when the printer works. Try a new USB cable and a different port, if you are using that connection. If you are on a network connection, check that the firewall isn't blocking communication. (Temporarily disable the firewall to check.) In Windows, check the Devices and Printers (Win7's name) control panel and check if the scanner is a listed device. Right click on it and check the properties and status. (All-in-ones are often listed twice - as a printer and as a scanner.) HP offers a diagnostic program, http://h10025.www1.hp.com/ewfrf/wc/doclink?lc=en&cc=us&product=1153754&tmp_docname=c02114802 , to check for issues with the scanner.
Try manually scanning with another program than the HP software. Windows includes some options that will acquire scans. XP, Vista and Win7 all include Paint (File > Import from Camera or Scanner > New Scan). Windows7 (and some versions of Vista) include Windows Fax and Scan (click New Scan). If you have the Microsoft Live software, you also have Windows Photo Gallery (works like Paint).
If you are connect the all-in-one to a USB print server, the scanner probably won't work. Try a different type of connection.
If you are using the all-in-one on a network, make sure that the network is up and the printer has an IP address. I've seen routers lose their connection for various reasons. (Rebooting both the modem and router sometimes cures the problem.)
Please add more information on your specific scanner problem and I'll try to provide specific suggestions.
I hope this helps.
Why isn't it scanning a document to my laptop
Make sure the Lexmark OCR scan software is installed on your laptop. The software is available only on the installation disc that came with your printer. If you still haven't installed the software on your computer and you don't have the installation disc, please contact Lexmark Technical Support Center to request for one.
If you were able to scan documents before using your Lexmark printer, it could be just a slight communication issue. A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
I have installed HP PHoto and Imaging Softward for ScanJet 3570c 48 bit. Everytime I try to click on icons on the scanner, my computer shows an error message that there is a problem with connecting to the...
Does the same error occur if you launch a scan from the computer? What OS do you have? Vista only has a basic driver available and does not support the scanner buttons. (You can launch the scans from a number of options: third-party software, Windows Fax and Scan (new scan), Microsoft Paint (File > Import from Scanner or Camera > New Scan) and Windows Photo Gallery.)
If the error occurs when you launch the scan from the computer, try a new data cable and different USB ports. Try a direct USB connection if you use a hub. Then check your USB ports and the drivers for the USB. (For Windows, look in the Device Manager. Start > Control Panel > System > Device Manager (exact directions will depend on the OS).
The HP Photo and Imaging software requires you to set the default scan destinations in the software before you can use the buttons on the scanner (for those OS/driver versions that support the feature). Always open the software and scan from the computer to see what the defaults will be. Each version of HP's imaging software set up these buttons differently; the help option is useful. Try Scan > Scan settings to find where to set the color and black & white destinations.
I hope this helps. If you add a comment with your OS and whether the computer can launch a scan, I'll provide additional help if I can.
(who inherited a scanner when a USB hub failure aggravated the original user into buying a new scanner thinking it was a scanner problem.)
1helpful
2answers
HI, i have a IBM thinkcentre S50 8086-21G and after resinstall on my hard drive the XP SP2 version , i don't have access about the USB connector and can you help me about this? i don't find the...
What exactly are you trying to connect to the computer via usb? If your talking about generic devices such as usb mice and keyboard then you will need to reinstall windows again. Devices like these use a generic usb driver that is installed during windows xp installation. There isn't really anyway to install this driver that I am aware of other then a clean install of windows
You could attempt to repair the windows system files, but I can't guarantee it will help.
You will need a windows xp disc. -Insert the disc. -Press the "Start" button -Click on run -Type "cmd" and press enter -Type "sfc /SCANNOW" and press enter
This will check for problems with your system files. Hope this helps
Clean install of windows (Delete all partitions and re install fresh) would be the easiest way to fix the driver problem. I did also find this article on how to manually install the usb driver. Best of luck http://support.microsoft.com/kb/329632
Logitech wireless mouse (m305) isn't working
Does this mouse need to sync with the reciever plugged into the computer?
Somewhere on the mouse and posssibly on the reciever plugged into the USB
port on the computer it should have a connect button. Usually to connect/sync
a mouse or keyboard press the button on the reciever first then press the connect
button on the mouse. Or if th mouse has a button just press the mouse button,
often the mouses lazer will blink until the mouse connects with the reciever then
just stay lit at this point it sould work. Another Question, how are the batteries in
the mouse?
Scanner doesn't scan
Start by changing the USB speed...
Two USB modes are available: Fast, which is the default, and Slow. Poor USB operation may be experienced in the Fast mode, in which case the Slow mode should be used to improve performance.
  1. Press the [Menu / Exit] button on the Control Panel. 'System Data' will be displayed on the Display Screen.
  2. Press the [Down] arrow button until 'System Setup' is selected, and then press the [Enter] button.
  3. Press the [Down] arrow button until 'USB mode' is selected, and then press the [Left] or [Right] arrow button to select either [Fast] or [Slow].
  4. Press the [Enter] button twice.
  5. Press the [Menu / Exit] button, and then press the [Stop] button to return to the Standby mode.
k24674
Grand Canyon Tech
Grand Canyon Tech
