20 Most Recent
Lexmark X5650 All-in-One InkJet Printer Questions & Answers
What is an ORC?
ORC is life form in the Lord of The Rings. What you want is OCR which stands for Optical Character Recognition. It is the software that converts a scanned document into a string of characters that you can edit to correct OCR errors.To be able to scan to a computer the computer and the printer must be connected through a USB port or be part of the same network. When you press the scan button, the printer tries to communicate with the computer and launch the scanning software installed on the computer.Install the software that shipped with your printer, connect the computer and the printer. If everything is correctly connected and installed, the scanning software will open to receive the scanned document.
Lexmark x5650 printer won't come on
Try these:
- Plug printer straight to power outlet in the wall. Bypass any surge devices or power strips as they can draw away power from the printer.
- Properly secure the power cord.
- Unplug the power adapter from the printer, replug after 30 seconds. The power adapter is the rectangular black box, behind the printer where the power cord is attached. Check if it's warm or cold. It can be a defective power adapter.
- If you have access to a voltmeter, test power adapter(30V output).
If problem continues, contact Lexmark technical support.
How can i use ocr on lexmard 5650
If it didn't come with any OCR software you can find some free OCR software by Googling free OCR. After you have the software installed, it's usually a case of browsing to the scanned image via the software and telling the application to convert the image into a Word document. Some applications have the ability convert to PDF as well. If you prefer a PDF document but your OCR application doesn't support that option, then download some free "print to PDF" software. Typically with this type of software you will not be able to edit a PDF like you will a Word document. Hope I was able to FixYa, please remember to rate my solution. Thanks.
I installed new cartridges (Lexmark brank both black and color) and my printer won't work now.
A quick fix for most communication errors can be achieved by
resetting the printer and/or rebooting the PC. Simply disconnect the printer
from your computer (if USB connected)> reboot your pc > unplug and
re-plug the printer into the power source to reset it. When the printer turns
on, reconnect it to your computer (if USB connected). Then try to print again
once the computer fully recognizes the USB connection or when the WiFi light on
the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
- Disconnect the USB cable
connecting the printer from your computer.
- On your computer, go to Control
Panel > Printers and Faxes.
- Delete the Lexmark print
object.
- Reboot computer.
- Re-brick your printer by
pulling out the power supply - black box where the power cord is plugged
into on the back of the printer, and re-plug after 30 seconds.
- When the printer turns on,
reconnect it to the computer.
- Wait until your computer fully
recognizes the USB connection. To check, go to Control Panel > Printers
and Faxes. If you see a new Lexmark print object in the list, try to print
a document to verify that the problem is fixed.
My X5650 print jibrish, does not print the words in a rihgt direction, print the words in opposit
do not re-install,
1. disconnect the printer from the computer
2. download and install (do not install any junk which you do not want - only ccleaner!) ccleaner, choose free version (of course nothing is preventing you from purchasing other versions):
http://www.piriform.com/ccleaner/download
3. open ccleaner
4. go to "tools" uninstall printer and all related programs from tools, while you are at it - uninstall all junk which you accomodated and never used...
5. run (in ccleaner) "registry", repeat till you have "no errors find"
6. run (in ccleaner) "cleaner"
7. reboot your computer
check and download updated drivers/programs for your printer here (check if you run 32 bit or 64bit!):
http://support.lexmark.com/index?page=product&locale=en&productCode=LEXMARK_X5650&segment=SUPPORT&userlocale=EN#1
run installation and follow instructions, this should solve your problems, if it is printing in reverse - it will be in settings of the printer, you need to revert it to "normal", or follow this little instructions...
hope this will help you - do not forget to vote...
Dont have the installation c.d. for Lexmark X5650, either. Plus, why does my printer pull the paper in crooked and WONT print! AND THAT CAUSES A PAPER JAM, then when you pull the paper out, the same t
Baring any damage to the load or eject trays, Check the back of the eject tray with a flash light by opening the top of your printer where you insert your cartridges. (make sure power is off first so that cartridges will not move over and be in the way.) . Next, check for any obstructions of paper, dirt, or foreign objects.
Next if there is nothing to be found, use a pencil eraser and a couple cue tips and rubbing alcohol to clean residue that builds up on the rollers where the paper feeds through.
Screenshot
Close the top, make sure that the load tray is not damaged and is inserted properly. (You can remove the back 2 screws on the load tray and get access to the inside to check for any other obstructions and cleaning.)
How do I put the printer control panel down on the Lexmark 5650
It latches into place and is intended to stay in place, once pulled out. From a Google Search:
"If you place your fingers up behind the control panel in the middle you will find a release button allowing the panel to turn back in. It is right up against the bottom straight edge underneath right behind the display and just below the scan and fax button. Press in on the edge and with two fingers while pushing in with thumb."
Cartridge error cartridge is stuck wont print
The
problem could be due to a communication failure between one of the printheads
(cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps
below to identify and fix cartridge issues:
- Make sure the printer is on.
- Open the printer cover. The
print cartridge carrier moves and stops at the loading position, unless
the All-In-One is busy. Note: If the carrier does not automatically move
to the center, turn off the printer or unplug the printer from the power
source and then carefully slide the carrier to the center.
- Remove both cartridges from the
carrier.
- Close the printer cover.
pulling out the power supply - black box behind the printer where the
power cord is plugged in to, and re-plug after 30 seconds.
reinsert one cartridge first. Close the printer cover and check for any
errors.
- If no error appears, reinsert
the other cartridge. Close the printer cover.
- Replace whichever cartridge is
causing the error to appear with a new genuine Lexmark cartridge. Try to
print a document again to verify that the problem is fixed.
Printing
Normally if you say 'Print this email' it prints all the pages automatically. Try going on to the Advanced printer section and where it says print pages from... to... give page numbers
Login in facebook
Not from your printer.
Point your web browser at
http://www.facebook.com
If another account comes up, log out of it by clicking the little gear icon in the upper-right then clicking "Log Out."
If you then still can't log in to your account, click the "Forgot your password?" link located just below the password box on the login page.
