I have a bizhub c450. Recently, the machine displays the following message: "please replace imaging unit(s) follow: imaging unit yellow" Can I do to delete this message? However, using the device control panel how ?
SOURCE: Bizhub C450: After replacing the image transfer roller & ozone
In Service Mode -> Counter -> Life -> Select the one you want to reset and press 'C'
SOURCE: Reseting counter after installing new image transfer roller unit
You need to go into tech rep mode to reset.
press: stop 0 0 stop 0 1, then 0 0 0 0 0 0 0 0, press enter, then press counter on the left, select life, then highlight image trans roller and press the C button, repeat for paper dust remover and exit tech rep mode
SOURCE: Imaging Unit Problem with bizhub C450
On the end of the image unit you will find a white bit of plastic with a small screw in the middle, make sure this screw is tight and then reinstall the units(give the units a bit of a shake too)
SOURCE: C-2451 on bizhub c450
C2451: New Transfer Cleaner Unit resetting failure
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch
ON while pressing the Utility/Counter key.
3. Touch [Trouble
Reset].
4. Check to make sure that [OK] is displayed and the
it has been reset.
5. After turning off the Main Power
Switch, turn it on again more than 10 seconds after and check if the machine
starts correctly.
Reset your Toners and
Imaging units for Minolta Bizhub and CF series.
http://www.chipreset.eu
As Prithi suggested or you can buy a setter such as the following and reset the page count yourself:
https://www.kopy-kat.com/EZ350.html
