20 Most Recent Konica Minolta bizhub C450 Scanner Questions & Answers
Bizhub c450 stuck on scan-to-fax
Did you set it up to scan to email. info such as authentication, smtp server, valid email address use the copier web page to install this info.
4/28/2019 6:15:52 PM • Konica Minolta... • Answered on Apr 28, 2019
Bizhub c450 what is job has been done improperly check the log
Go to "job list" select job high lite then touch details what does it say???? Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/18/2018 10:37:28 PM • Konica Minolta... • Answered on Mar 18, 2018
Error code c-6751 on konica minolta c450
The CCD is bad raise the document feeder. under the big glass to your left is the CCD assy. Unless you know which screws to remove you remove the wrong ones and all your images will forever be messed up. so recommend a tech come out and replaced it. have open close the front door to reset the code Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
6/11/2017 11:09:59 PM • Konica Minolta... • Answered on Jun 11, 2017
Konica c 450 touch screen hang and solution
what is "hang" Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/14/2017 10:56:18 PM • Konica Minolta... • Answered on May 14, 2017
Error bizhub c450 c9401
The bright lamp under the big glass is burned out or the circuit board that controls it is bad try this first if the code comes back get tech out to look at the lamp or board. 1. Turn OFF the main power switch. 2. Turn main power switch ON while pressing the Utility/Counter key. 3. Touch [Trouble Reset]. 4. Check to make sure that [OK] is displayed and the it has been reset. 5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly. Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
5/14/2017 6:57:04 PM • Konica Minolta... • Answered on May 14, 2017
Why doesn't ADF detect paper?
how do you mean Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
3/12/2017 3:29:15 AM • Konica Minolta... • Answered on Mar 12, 2017
When I scan a white or Blu or green line on my paper scan show
It might be that you need to clean the printer heads. Your manual should tell you how to do that; also you might be able to Google an online manual for you printer model.
7/11/2014 3:44:36 AM • Konica Minolta... • Answered on Jul 11, 2014
0answers
Error 2551 with p 6 on and truble reset dosent help
Dir sir. Ineed BenQ 5000 Model 6678-9vz scanner driver please send me my mail
4/17/2013 1:46:56 PM • Konica Minolta... • Answered on Apr 17, 2013
0answers
0answers
Konica Minolta bizhub C450 Scanner Logo
43 questions posted
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Konica Minolta Office Equipment & Supplies
Most Popular Question
error 2551 p 6 truble reset dosent help
  • Office Equipment & Supplies
