I have a WD elements 1042 usb , one day it was working perfectly , now i can enter or access any information on it , i even can't see the partition in my computer , but i can see the hard disk in computer management as unallocated partition , i tried to format it but with no luck , i used a software from WD website for formating the hard disk with no luck too, so if any one can help me it would be great , i don't wan to lose the data on it but if the is no other way so be it.
SOURCE: i can't access my wd
Hello
Have you tried accessing the hard drive on another computer?
Have you tried using a different USB cable?
Was the hard drive dropped or moved while it was plugged in?
Check the WD Site if you hard drive has warranty.
I hope this solves your problem and please reply if you need more help.
SOURCE: WD ext hard drive cant access files - I/O error (think its bust)
Chances are the drop jarred loose something in the drive that on;y caused problems when the disks stopped spinning and started again. Here is a list of recovery tools that would do the job if there is something there to recover. http://www.snapfiles.com/Freeware/system/fwdatarecovery.html
you will know within a couple minutes whether there is anything recoverable.
If it is that important you can send the drive off to www.OntrackDataRecovery.com and they should be able to get the files.
