Lenovo 3000 C100 Notebook Logo
Posted on Apr 17, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Touch pad not working
I have Lenovo c3000 c100 but its touchpad is not working when i plug the charged then its sometime working or not so please tell me the solution of this troubleshoting
Anonymous
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 174 Answers
  • Posted on Apr 17, 2012
Anonymous
Expert
Level 2:
New Friend:
Cheetah:
Answers
174
Questions
Helped
40907
Points
337
I would say its the batterie, try to put the batterie out just connect it with the cable, in have that to i actually let it connetd even i know its not good for the computer the bad batteries make your pad for sure not better so watch out
5 Related Answers
Walter H Boehm
  • 998 Answers
  • Posted on Oct 17, 2008
SOURCE: dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Anonymous
  • 86 Answers
  • Posted on Jan 28, 2009
SOURCE: mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
 If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
Anonymous
  • 54 Answers
  • Posted on Mar 14, 2009
SOURCE: touch pad scrolling problem
Use alps one as well as check weather your touch pad is lock or not
Nandakishore
NANDAKISHORE
  • 304 Answers
  • Posted on Apr 14, 2009
SOURCE: i want audio driver for lenovo 3000 C100 can u
Please find here enclosed URL: http://www-307.ibm.com/pc/support/site.wss/MIGR-63531.html
Download and install.
Thanks & regards
Nanda Kishore.
Anonymous
  • Posted on May 17, 2009
SOURCE: touch pad not working correctly
If u are having Synaptics Driver....then
check that Tapping is enabled...
follow steps to know that:
Open Control Panel..
Now Open Mouse
Now click on tab "Device Settings"
then Click on "Settings"
a new window popups
Click on "Tapping" which is listed on the corner of the window
Now after clicking on it...on the right...check that there is "Tapping Enabled or not"
if not...click on that White box...
and Apply
then ok
Done :)
_________________________________________________________________________________
Sorry 4 my english!
Work my Quantary touch pad
Have you tried an external mouse to ensure that the pointer works?
Usually these problems are due to either a defective pad driver or a history of a spilled liquid contaminating of the contacts, or a settings issue (i.e. touchpad is turned off). Hve you trued any of these obvious problem areas?
Please provide a few more details such as Win OS version, TouchPad driver version, etc.
My mouse touchpad stopped working all of a sudden. I have also enabled the synaptics touch pad in device settings in the control panel. after doing all these also my touch pad is not working.
Check the keyboard it's possible the touchpad has been deactivated. You can toggle fn keys (fn + f2) or any fn key that has touchpad drawn on it. If this doesn't help. Am afraid the touch pad connector has to be checked & replaced in computer repair shop
Touch Pas/Mouse no working
again try it without batterie it must be the batterie try only with the cable direct if its than still than you know it something with your pad which i dont think
1helpful
2answers
Hello My HP G60 549DX touchpad started having problems, while the laptop is charging the touchpad wont work(sometimes, not always) and the touch click wont work, i have to use the right click...
It isn't likely that your laptop charger is the problem and it is more likely that is is just your touch pad. So you shouldn't buy a new laptop charger unless you absolutely think you have to. If you do, make sure that you buy it from HP instead of a third party for a lower chance of problems. It's more likely that it's just your touch pad that is faulty.
4helpful
2answers
Lenovo touch pad not working properly
Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
Problem related to touchpad not working properly
for you have used the machine for more than 1 year then your touch pad need to be replaced however if it has happened abruptly then reinstall the touch pad drivers
1helpful
Please update the Touchpad driver from www.lenovo.com
11helpful
3answers
Laptop's touchpad not working
Please remove the external mouse and press Fn+ESC simultaneously the issue should be resolved.
Thanks.
4helpful
Mouse touch pad problem Lenovo Y410 model notebook
Top Lenovo Computers & Internet Experts
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
