20 Most Recent
Lenovo IdeaPad Y510 Core-2 Duo: Y510 Series IdeaPad - Core-2 Duo T5750 Processor; 3072M Memory; 250G... PC Notebook Questions & Answers
My mouse is not working like it used to. I have to
Does you mouse have a ball? If so, it needs to have the ring that holds the ball into the bottom taken off and the tiny white nylon rollers inside the mouse need to be cleaned, I use a toothpick or a wood match stick. The rollers get lint on them, If you have an electronic ( laser) mouse ( like with a red light), it needs to be blown our with high pressure air or maybe replaced. Be blessed.
Stk770d
Please refer to this link to find the exact file you are looking for:http://consumersupport.lenovo.com/ot/en/driversdownloads/drivers_list.aspx?categoryid=43
AUDIO DRIVER
go here to get your download
http://www.laptops-drivers.com/lenovo-laptop/lenovo-ideapad-y510-notebooks-driver.html
Hello...i use a lenovo laptop and when i tried to
try this tip, nimmiti_lava
click start > run > type regedit
click HKEY_LOCAL_MACHINE , then click SYSTEM
then click CURRENTCONTROLSET, then click CONTROL
then click CLASS, then click the folder 4D36E965
delete the LowerFilters & UpperFilters on the right side of the registry
then restart the pc
Hope this helps...
Can't find drivers for win 7 64-bit for lenovo y510
Windows 7 is a new platform and every hardware manufacture is developing the driver suits for it.Meanwhile you will have to download the drivers directly from the chip manufacturers site e.g. for sound you can download it from
http://www.realtek.com.tw/downloads/.
About the chip manufacturers you can know from the Y510 page where the drivers are there for Vista or XP.
Thanks.
When i start my laptop ....
well I've encounter that before, ok this is what you can do..
XP installer cannot solve the problem..
try to download trial version of widows 7 installer on microsoft website, once you ave it in cd or dvd,
just put it on your cd rom drive and have it start all over again, when prompted to boot on cd, click enter
install the windows 7 directly, after clean installation, then you'll find that your laptop is ok
it is up to you if you would like to keep the windows 7 as your OS or downgrade it to vista or xp.
beware that windows 7 still have a driver issue, but it is working.
if you gonna need genuine serial key, please contact us by subscribing as a premium member and I will provide you genuine serial key
Dell laptop with runtime error
Short Form (for Experts only):
Delete the file Vgraph.dll from \WINDOWS\ OR any other place resident
Long Form: (Estimated Burden: 1-5 Minutes)
STEP 1:
DELETE ALL YOUR INTERNET EXPLORER (IE) TEMP FILES AND COOKIES BEFORE YOU CONTINUE.
METHOD:
If your IE is hung up:
Click on Start/Settings/Control Panel/Internet Options/#
If your IE is not hung up:
Click on: TOOLS/INTERNET OPTIONS/
#GENERAL TAB/TEMPORARY INTERNET FILES/DELETE COOKIES & DELETE TEMP FILES
STEP 2:
NOW UPDATE ALL Objects/Downloaded Program Files
METHOD:
#GENERAL TAB/TEMPORARY INTERNET FILES/SETTINGS/VIEW OBJECTS/ SELECT ALL, RIGHT CLICK, UPDATE
OR
WINDOWS\Downloaded Program Files SELECT ALL, RIGHT CLICK, UPDATE
Note: If update takes too long then keep in mind the ones that have been updated and skip the ones that take too long.
STEP 3:
Under IE's Manage Add-ons disable the CvgraphObj Object
---> Tools/Manage Add-ons (Alt+T in Internet Explorer)
Click on Start/Settings/Control Panel/Internet Options/Programs/Manage Add-ons
Now Disable the CvgraphObj Object
STEP 4: Restart INTERNET EXPLORER
STEP 5: SMILE :-)
If this does not work for you then read below
STEP 6: Try to find Rogue Applications that are installed as objects. Anything suspicious--> Disable it
HOW TO EJECT A DISC IN LENOVO IDEAPAD 330
The CD/DVD drive may be opened by pressing a button on the drive itself. If the drive does not open by pressing a button on the drive itself, or the button is not available on the drive, Windows natively provides the ability to eject the tray with simple methods that can be performed in the File Explorer. The steps vary from different operating systems:
Note:
- Not all systems come with a CD-ROM, CD-RW, or DVD drive installed internally to the computer
- To verify that, you can check the left and right side of your machine. See if there is any slot to insert your CD/DVD. Normally, there is a button to eject the CD or DVD tray for you to insert a disc
- Another method to identify this is as below:
1. Click Start and type Device Manager in the search box. Select Device Manager
2. In Device Manager look for DVD/CD -ROM Drives
If you don"t see DVD/CD -ROM Drives this means your device has no optical drive hardware. An external optical drive will need to be purchased to run CD/DVD. It is also wise to check your product specification to see if your device has an optical drive.
If you were previously able to play CD/DVD and DVD/CD -ROM Drives has disappeared from device manager or your device is not reading the disc please follow > Your CD or DVD drive is not recognized by Windows or other programs.
- The format capabilities of the drive are listed on the label on the external cover of the drive
- The CD-ROM, CD-RW, or DVD drive can be opened using the emergency eject hole (Bend away a leg of a paperclip to work with. Insert the paperclip slowly until there is resistance, then gently push until the drive door is opened) Applicable Brands
Solution
·Windows 10
·Windows 7 Eject disk tray with File Explorer
- Turn off all applications currently using the drive. Otherwise Windows will prevent you from ejecting the DVD tray
- Hold Windows + E on the keyboard to open File Explorer
- Click the DVD drive icon and click the "Eject" button on the toolbar or right-click on the optical drive and choose Eject from the menu that pops up or down.
