Music Logo
Anonymous Posted on Apr 16, 2012
Kurzweil pc88 sound cuts out
After about 20 seconds at normal volume, the sound cuts down the volume. I have put in new battery already.
Andre Blum
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Aug 26, 2018
Andre Blum
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
934
Points
I had this same problem. Pressing the panic button restored full volume, but again only for some seconds. I went to the 'midiscope' feature (in the global menu) to show any midi control messages that could be the cause. Indeed, it showed midi control message with volume, even though I did not touch any controls and no external midi devices were connnected. The midi scope in my case showed message was coming from midi channel 1, controller 11, which didn't mean much to me. I moved all knobs and sliders, like the pitch wheel and volume sliders and saw similar messages in the midiscope, but all on different controller numbers, not #11. Then I thought it could be coming from the external controller connectors on the back. I connected a foot pedal to them and found #11. With finding it, and by doing so, maybe cleaning or moving something in the plug connector, the problem disappeared and did never reapper.
1 Related Answer
Anonymous
  • 1212 Answers
  • Posted on Sep 25, 2012
SOURCE: kurzweil eg 20 piano keys sinking
You may not have the patience level to attack it. Few ppeople do.
Kurzweil Mark 12 Where are the batteries located ?
https://kurzweil.com/wp-content/uploads/2019/10/MK12_152_USER_MANUAL.zip
user manual - unzip
refer to page 108
mentions a cover plate that has to be unscrewed.
Would suggest 3 x alkaline AA batteries long life
you have 30 seconds to replace them before loss of memory
Mar 03, 2022 • The Music
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
1helpful
I have a Kurzweil pc88. The unit function but the power board 7805 voltage regulator overheats and eventually shuts down after 7-8 minutes. All else appears functional. Any suggestions?
Try changing out regulator . Check voltage output and resistors are a good culprit in these cases. Are you sure the rectifiers are doing there job ?
Feb 23, 2015 • Music
1helpful
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Tell me some tips and tricks about using the Kurzweil sp3x stage piano
The place to get the best help for Kurzweil gear is Sweetwater Sound.
Other than that, always use it in stereo mode with a decent sound system. Always use speakers with at least a 15" woofer and a horn to get the full range of sound it's capable of.
1helpful
Replacing battery in kurzweil mark 12
As per the manual it says it is located near the power switch. You will need(as per the manual instructions): a screwdriver(Phillips head), a knife, a pair of scissors, and a pair of front end wire cutters as, when shipped from the factory, the three AA batteries were taped or cable tied as a shipping precaution(to keep them from falling out). ***WARNING: MAKE 100% SURE YOU HAVE BACKED UP ALL OF YOUR SOUND PATCHES ON A FLOPPY DISK BEFORE BEGINNING THIS PROCEDURE!!! ONCE YOU START THE REPLACEMENT PROCESS, YOU HAVE ABOUT 30 SECONDS BEFORE THE BOARD LOSES ITS CHARGE AND YOUR SOUND PATCHES GET ERASED FROM THE ROM CHIP.***
Make sure you have all of the needed batteries and tools before beginning.
Hope this helps.
How to change battery in the Kurzweil PC2x?
To change the battery in a Kurzweil PC2x, follow these steps:
  1. Power off the device and unplug it from any power sources.
  2. Remove the screws on the back panel of the device to access the battery compartment.
  3. Carefully remove the old battery, taking note of its orientation.
  4. Insert the new battery in the same orientation as the old one.
  5. Replace the back panel and screws.
  6. Power on the device to ensure that the battery change was successful.
Kurzweil eg 20 piano keys sinking
My kurzweil micro piano will come on and the lights are on but theres no sound,even the demo will not play.the unit is plugged in correctly.i have not used it for several years.
Just make sure you are not sending out a midi volume from your keyboard, this could turn the volume down or off. I am not sure what else could cause this. hope it helps.
Apr 19, 2010 • Music
3helpful
Kurzweil Mark 10 keyboard stopped working
Try the reset procedure on page 5 ( last page ) of this pdf document:http://www.dgaudiorepair.com/PDF%20Files/HARD%20RESET%20for%20Current%20KURZWEIL%20.pdf Hope this helps. Note the first procedure says highest white key. I'd do the second procedure.
Aug 27, 2009 • Music
Top Music Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Music Expert? Answer questions, earn points and help others
