20 Most Recent
Kurzweil SP3X 88-Key Stage Piano Questions & Answers
Kurzweil sp3x tips and tricks
The Kurzweil SP3X is a popular stage piano known for its high-quality sound, responsive keyboard, and versatile features. Some of the advantages of the SP3X include its excellent sound quality, which is achieved through Kurzweil's advanced sound engine and a variety of realistic instrument sounds. It also has a highly responsive keyboard that is suitable for playing a wide range of musical styles. Additionally, the SP3X has a variety of features that make it a versatile and useful instrument for live performances, such as its built-in sequencer, arpeggiator, and various effects. Overall, the Kurzweil SP3X is a reliable and powerful stage piano that is well-suited for both professional and amateur musicians.
Cuts out on me while playing
If you';re sure it's the instrument, rather than your amp cutting out or the cord being intermittent, do a factory reset. Beyond doing a reset, it's doubtfull this will be a user servicable problem. You need to contact Kurzweil Support. Here is a link to their page
Support Kurzweil
Gets whacky and freezes up every 2-3 minutes
Is this the correct sustain pedal for this unit? It sounds like it should be a momentary button type. I would look into that. Some have a push to work type of switch and some use momentary. If it is, I would open that pedal and clean the switch with contact cleaner, as it appears to be sticking.
Hello, My KURZWEIL start
It could be your internal battery. Do a search on keyboardforums.com for additional support or Kurzwil website. good luck!
I brought my kurzweil sp
It sounds like the new board and firmware has gone to abbreviations instead of fully spelling it out.
I would complain to the store since they should warrant it if it is a problem... but be prepared to accept that the firmware has been changed and displays differently now.
After transport the keyboard,half of
Probably a cable has come loose inside the unit. The keys are scanned by the internal processor as a matrix of two contacts per key. Often the keyboard is divided into two sections.
You will need to have it repaired or if you are electronically adept, open the case and look for obvious problem.
How do I restart when Kurzweil Mark 12 1999 piano hangs at waking up scanner message?
Hard reset procedure
1. Turn the Kurzweil off
2. Hold down the KEY START, KEY STOP, and LAYER VOLUME buttons for 5 seconds while powering the unit up, then release
3. Select RUN DIAGS
4. Press the UP arrow until the display reads RAM TEST
5. Press the START/STOP button to run the test
6. When the display reads SUCCESS, turn the unit off and back on. The unit is now reset.
If your Kurzweil still does not come up to the normal screen after this procedure, it will require service.
