I bought a sports watch from GAP. there are 4 buttons, Light, Mode, Start, Reset. When I push the Mode, the only the weekday changes and it looks like it is Alarm setting not date. Please help me.
My sons watch is stuck in military time and I have no idea how to change it back. It is a cheap Sport Watch from Gap, but he loves it. Any ideas?
Re: How do I adjust date of my watch bought from GAP
I think I figured it out:
(Start + Reset) = toggle alarm on/off ("ALM" will display in upper left corner when alarm is on.
(press Mode once) will bring you in chrono mode, where "start" button starts and stops the chrono, and "reset" button resets it back to zero
(press Mode once more) will bring you to setting of time for alarm. Set the "hour" value by pressing "start" repeatedly, then press "reset" and set the "minute" value by pressing "start" repeatedly
(press Mode once more) will bring you to setting of time for actual time. Reset the "Seconds" value to zero by pressing "start" button once, then press "reset" and set the "minute" value by pressing "start" repeatedly, then press "reset" and set the "hour" value by pressing "start" repeatedly (if it shows "H" in upper right corner, time will be displayed euro-style 0:00-23:59, if it shows "A" time will be displayed 12am/12pm), then press "reset" and set the "day of month" value by pressing "start" repeatedly, then press "reset" and set the "month" value (1-12) by pressing "start" repeatedly, then press "reset" and set the "day of week" value (Su-Sa) by pressing "start" repeatedly
(press Mode once more) voila!
I wouldn't say I know for sure how to fix this problem, but I had some success.
I bought the same watch for my son and it was days before I could figure out how to change the time. It was an hour behind and the day and date were wrong on it. I finally just kept pressing the mode and reset buttons until I finally stumbled into the mode to change time. Just kept pressing buttons until I got the numbers flashing in the right spots and pressed the start button to change numbers.
I had the same issue where it seemed like I was only changing the alarm.
Just keep trying! It's a total pain that it didn't come with instructions or have them on the website or something.
If you can give me a specific model, l can give you specific answers...it sounds like you are in the alarm mode, and this watch can be set to activate the alarm on given days....the date is in the time-set mode (military adjustment is also there)....go thru modes until the seconds flash....this is time/date set mode....then select thru the different settings....ie, hours minutes, ect....the watch will rotate to the date set section....happy hunting!!...d.
TIME AND DATE
1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
2. Press ADJUST to set SECONDS to zero.
3. Press START/STOP to select MINUTES.
4. Press ADJUST to change.
5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
6. Press MODE when done.
7. To display DATE from Time display , press START/STOP.
8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
4. Press ADJUST to change.. Press MODE when done.
5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
2. With time displayed, press MODE to select Chrono Mode.
3. Press START/STOP to start.
4. Press ADJUST to view lap time. Press again to resume lap timing.
5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
6. Repeat for successive laps.
For the Amritron 45/6975: From the "Time Telling Mode" (date/time displayed): to set the date and time: Press "reset" unit the date disappears--release; press "mode", the "hour" will flash, press "st/stp" to adjust hour; press "mode", the "minute" will flash, press "st/stp" to adjust minute; continue same sequence to adjust date; when done, press "reset"
For setting Time & Date... 1. Push "MODE" button three times (change Mode to TimeSet) Time -> StopWatch -> AlarmTimeSet -> TimeSet -> Time ->... 2. Flashing Second Number Digits 3. Push "RESET" to select... Second -> Minute -> Hour(12hr<->24hr) ->... Date -> Month -> Day of Week -> Second -> ....(repeat) 4. Use "START" to set each item...
For setting Alarm ON/OFF 1. Push "RESET" button then Push "START" same time... Alarm ON -> Alarm OFF -> ... (repeat)
TIME AND DATE 1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash. 2. Press ADJUST to set SECONDS to zero. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change. 5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM. 6. Press MODE when done. 7. To display DATE from Time display , press START/STOP. 8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE. 9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME 1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash. 2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM. 3. Press START/STOP to select MINUTES. 4. Press ADJUST to change.. Press MODE when done. 5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH 1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes. 2. With time displayed, press MODE to select Chrono Mode. 3. Press START/STOP to start. 4. Press ADJUST to view lap time. Press again to sesume lap timing. 5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero. 6. Repeat for successive laps.
Dear gap.com Customer,
Thank you for your email regarding the Sporty Printed Watch user instructions. Please accept our apologies that no directions were received with your order.
The instructions are as follows:
Button Functions:
A. Light B. Mode C. Start D. Reset
Standard Time Adjustment:
1. To set the time, press the Mode button three times (The seconds and the word Tuesday should start flashing).
2. If the seconds position shows less than 30 seconds, pressing the Start button will reset the seconds to 00. If the seconds position shows more than 30 seconds, pressing the Start button will reset the seconds to 00 and the minutes will increase by 1.
3. Press the Reset button until the area you want to change starts flashing (i.e., second, minute, hour, day, month, and weekend. Press Start button once for per unit increment, press and hold for 3 seconds for speedy advance.
4. At completion, press Mode button to resume standard time display.
To reset the Alarm:
Press the B: Mode button until you reach the alarm.
Press the D: Restart button.
Press the C: Restart button to get back to the time
hello,to set the date:
push and hold the mode button for 3 seconds,then push the mode 1 time it will take you to the time,press the st/stop 3x's to reach the month,use the lap/reset button to change,4x's to reach the date,use the lap/reset button to change,5x's changes the day of the week,use the lap/reset button to change.when yor done push the mode button to set.
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US) These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
CHRONOGRAPH
Have fun! - Not a bad watch for the money! - - Silver Bullet
