20 Most Recent
Columbia All Sport Digi Watch l Questions & Answers
Columbia CL-5009
Use this link and browse through my TIPS AND TRICKS: http://www.fixya.com/MyProfile/tips.aspx?usrid=1700524. You will find manual for your watch there.
How do you change the
Press the "MODE" button---usually on the lower left side of the watch, but sometimes on the right center side---to cycle through to the time display.
Step 2
Press and hold the "SET" button---usually on the right lower side of the watch---until the seconds flash.
Step 3
Press "MODE" repeatedly to cycle through the displays that flash: from hours to minutes to month to date and day. At the end of the cycle is the hour display option. Make this option flash.
Step 4
Press the "SPLIT/RESET" button below the face of the watch to change the hour display option to "24-hour display." This is the same as military time. If there is a "NEXT" button on the upper-right side of the watch, use this to advance to the 24-hour option instead of using the "SPLIT/RESET" button. You may need to press a "START/SPLIT" button instead a "SPLIT/RESET" button to cycle between 12- and 24-hour display. The "START/SPLIT" button could be located below the watch face or on the upper-right side of the watch, depending on the model.
Step 5
Press the "SET" button again. You are now done. All PM hours should be displaying hours between 12 and 23.
How do i set the time?
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please . .
I don't know how to
look by the side of the watch you will see a round metal. Pull the metal out and twist it.
Twisting it will enable you to adjust the set the time on your watch.
Take care.
Set the time
I assume that you haven't got the instructions.
Go to
"www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
Under
"Timing" you will see a link "PDF.............", click on this
and a
list of diagrams will appear. Choose the one that looks like yours
and
follow the adjacent instructions.
How do you set the time on a cl 5055
Go to
Under
"Timing" you will see a link "PDF.............", click on this and a
list of diagrams will appear. Choose the one that looks like yours and
How do you set the time?
You can get instruction from their web site.
Go to "www.columbia.com/Equipment-+-Accessories/Licensee_Landing,default,pg.html"
Under "Timing" you will see a link "PDF.............", click on this
and a list of diagrams will appear. Choose the one that looks like your
and follow the adjacent instructions.
