Belkin Wireless G Plus MIMO (F5D9230-4) Router (1010835) Logo
Posted on Nov 10, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Belkin wireless stopped working.
My belkin router is 18 months old.i always leave it on,for some unknown reason it has stopped working and the lights have gone out?please adviced me. jenibod. :-(
Lara Douglis
Level 3:
  • Belkin Master 229 Answers
  • Posted on Jun 26, 2017
Lara Douglis
Belkin Master
Level 3:
Answers
229
Questions
0
Helped
240881
Points
1375
Well you can try to contact to belkin tech support and ask for online assitance hope they will fix your problem and you will be good to go.
1helpful
Belkin wireless stopped working - when re submitting WEP password, just says timed out
To reset the Belkin back to the default settings -
Press and hold the pinhole RESET button at the back of the router and then power for at least 15 secs. Then release the RESET button.
Connect a LAN cable from Belkin to your laptop/computer's LAN port, open a browser on your laptop/computer and enter the Belkin's configuration URL. http://192.168.2.1
The default PW = blank (just press Enter) You can now change the default admin password.
You can now configure the wireless settings to protect your wireless network and Internet from unauthorized access. Now configure the wireless card in your computer/laptop with the router's wireless settings. To secure your wireless network from unauthorized access, please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
1helpful
Hi, I have a belkin surf F7D2301 wireless router that has been performing wonderfully for about 6 months until the other day when it stopped working out of the blue. No power lights are on and it does not...
Before contacting Belkin to obtain a replacement of the unit, I'd suggest attempting to locate a different AC adapter for your router.
You never know, it may be bad and your router could be fine.
If you can't locate one, or the one you found didn't work, contact Belkin for a replacement.
http://www.belkin.com/contactus/
How to connect Belkin N N 300 Router to Cox Cable Modem step by step instructions. Cox just installed a new modem since the old one "went bad" and was giving a wrong "number". Was working fine before and...
Step 1 : Connect modem - Router - Computer ( Wired )
Step 2 : Open router setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left side under internet WAN click Connection Type
Step 4 : leave the Password Blank and click submit
Step 5 : Choose the connection type as dynamic and click next
Step 6 : Leave the Host name blank and click apply
Step 7 : On the left Under Internet WAN Click MAC Address
Step 8 : Click Clone and Click Apply changes
Step 9 : If the Internet status on the top right is connected
Step 10 : Then check if you have internet
Step 11 : if not Then unplug the Power Cable from the Modem And the Router
Step 12 : Plug the power Cord to the Modem
Step 13 : Wait till all the lights are on
Step 14 : Plug the power to the belkin
Step 15 : Check the color of the light in the belkin
Step 16 :If green then Check if you have internet
If not working then call belkin
================================================WIRELESS SETTING UP A WIRELESS CONNECTION
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
Step 3 : On the left under wireless click wi - fi protected setup
Step 4 : Leave the password blank and click on submit
Step 5 : Disable it and Click on apply changes
Step 6 : On the left under wireless click Security
Step 7 : Enable 64 Bit WEP
Step 8 : Type a 10 digit number on the key 1 ( 2 in each box )
Step 9 : Click apply changes
Step 10 : on the left under wireless click channel and SSID
Step 11 :Change the Wireless channel to 6
Step 12 : Change the SSID to a different name ( no Spaces )
Step 13 : Click apply changes
Step 14 : Now Scan and connect to this network ( Wireless )
Let me know if it works
We always lose connection with the router and have to restart it daily. Is there a reason for this? Thank You
By seeing your modem it seems to be a old make and check wither u have updated the firmware for the router,if yoy need to update the Firmware kindly download from the website as follows,
belkin.com/support
After downloaded update it in the router page by entering the 192.168.2.1 in the Internet explorer you will get a belkin router setup page
On your left hand sie click on Firmware update,it asks for login password,leave it blank and click on submit
Upload the downloaded file to the router and click on update
Regards,
Ayyasam
Connection problem for ps3 internet
cant you attach the old wireless router to one of the expansion slots in the new wireless router and have the old one for ps3 only and the new one for everything else
3helpful
New Belkin router wont connect to internet.
your user name and password have been entered incorrectly, they are case sensitive and must be exact. Make sure your ADSL settings are set at 0/38 (you'll see where)
My belkin wireless router has stopped working it only eighteen monthes old whats the solution
try reseting it to factory defaults using reset hole at back of the router in most cases corrupt config is at fault
2helpful
I unplugged the cable connected to my desktop and the wireless function stopped working
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
Wireless adapter used to work, then stopped, then worked again, now can't be detected...
you mean that the adapter is not being recognised by the pc as a usb device, this adapter works better on a usb2.0 port, not as well on a usb1.0 port, depending on how old your pc is, try other ports., but you must uninstal the belkin driver from add/remove programmes, then install the driver again and inset adapter in a different usb port than before.
the adapter should then be found and click install driver automatically, but leave the cd in the drive as it normally picks the driver up again from the disk on it's own even after installing it yourself.
When installed i would recommend using windows wireless zero configuration (windows own software) instead of the belkin software, to do this right click on the network icon and select enable WZC (windows zero config), as this is a more stable programme for connecting your adapter signal to the router
Personally Belkin is poor in my opinion, netgear has better software and drivers, but it's belkin you have, so follow the above and it should be ok.
Top Belkin Computers & Internet Experts
ExpressFiX
ExpressFiX
Alexander
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
