20 Most Recent Belkin (F5D8231-4) Wireless Router (F5D82314) Questions & Answers
what about to set the ps3 ip address on the DMZ for the router that will give all the ports open to that address and will play freely
try go to advance settings and firewall or game and applications there is where you will set dmz application .
Good luck
Belkin... | Answered on Mar 09, 2019
Wireless light will lit up only if any wireless computer is connected to Belkin's wireless network.
First, connect to Belkin's wireless network that you can scan.
After you connect, try to go online
It ll work...
Belkin... | Answered on Oct 30, 2018
It could be the proxy or firwall setting in the router.
you need to open the router page and check the firewall and proxy setting ..
or you can download the tool from the below site
www.ultrareach.com/
and it will take off all proxy setting and you winows messenger should work.
This should help you identifing if its a proxy issu.
THanks & all the best
Belkin... | Answered on May 17, 2018
This is part solution, part clarification request: When you say that you installed the setup software on your laptop, setup software for which: the modem, or the belkin router? Also what type of internet service do you have - Cable? DSL? If you are not sure, list your ISP. What operating systems do you have on your laptop and your main computer?
You say that you connected the modem to your main computer - I am assuming that you mean that you connected your modem with a network or ethernet cable (the one with a connector that looks similar to but larger than a telephone's connector) to your computer's ethernet card, or NIC, port. Is anything connected by ethernet cable to the Belkin router? If you have not connected the modem directly to the router, it will not connect to the internet, and anything connecting to the Belkin router will not be able to access the internet as well.
Try this: disconnected the power from your modem, then disconnect power from your router, and disconnect any ethernet cables from computer & modem, or computer and router. Connect an ethernet cable from the modem to the Belkin Router. (Ensure that you have plugged in the ethernet cable on the router into a port that is either set aside from others, or indicates "Internet", WAN, or something similar - it should be marked either with a different color, labled, or both). Now power on your modem. Wait until you see a steady "ready" light, green ethernet light, or the light usually lit for that model indicating it has completed its bootup tests and the internet connection is ready.
Next, ensure the ethernet cable is connected from the modem to correct WAN or "internet" port on the Belkin Router, then power up the router. Once the router boots up completely, plug in a cable from your computer's (main computer) NIC or ethernet card or port, to a port on the Belkin Router (there should be more than one port available, generally numbered "1, 2, 3" and so on - in a group, seperate from the WAN or internet port). Once you are sure you have the cable plugged into one of the correct ports, and if you have windows, restart your main computer.
Now on your main computer, check to see if you have an internet connection. If you do, you can now resume running the router's software setup on your laptop, which sounds as though it was walking you thru the setup process to connect you via wireless connection to the internet. Report back if you have any success, or if you have any further problems, and best of luck! Hope that info helps
Belkin... | Answered on Dec 04, 2017
Hi, since your Internet source is the ISP modem, you have to connect the cable from it to the yellow connector of Belkin router, then you can connect the VoIP router and computer to any of the ports (connectors) labeled 1-4 , remember to restart clients (PC & VoIP router) to get the new IP from Belkin router.
Belkin... | Answered on Nov 07, 2017
once you press RESET you will not be able to connect wirelessly, you have to configure the router. you can only do that via a LAN cable connected PC. switch router off for at least 10 seconds. attach a pc using a lan cable to ports 1/2/3/4 NOT to the WAN port(5). switch on the router and start your browser. type in either http://router or 192.168.2.1 to get router menu up. configure the router because you have RESET it. http://www.belkin.com/uk/support-article?articleNum=8181
Belkin... | Answered on Oct 18, 2017
Contact Belkin Tech Support At Toll Free Number- 1-800-585-2494
Belkin... | Answered on May 09, 2017
It seems like your router is configured once without any issues. Ignore that error message if you are connected with the internet. The setup couldnt find the Network adapter or the router because it is know more a factory default settings. It is been configured already
Belkin... | Answered on Apr 24, 2017
disable all firewalls in the computer first(windows and any 3rd party firewall)....then install the router...also disable any software that prevents you from performing any task.... basically for router you need not install any software...all that you need to do is connect the cable coming from the modem to the "wan" port(yellow coloured port) of the router... and connect your computer to any one of the grey coloured(wired) ports of the router... then type 192.168.2.1 in internet explorer and configure your router according to the ISP...the connection type would be dynamic in most of the cases for cable modem/dsl modem....
Belkin... | Answered on Apr 21, 2017
You must always have a 'host' adaptor whether you want a LAN or a WAN. Go to your configuration utility or control panel via your Run command to set or view your options. Steve Medley
admin usually gets u into the router for access WITHOUT a password. Set a new password or resetup your network with the disk that comes with your router.
Good Luck,
Jeff
Belkin... | Answered on Dec 21, 2016
Make sure your physical connection is correct. From the modem, the ethernet cable should plugged in to the Internet/WAN port of the router. And your computer to port 1. Access the setup page of the router again and Enable the MAC Address Clone setting. Clone the MAC Address of your PC there then power cycle the router and modem. You should be all set.
Belkin... | Answered on Dec 20, 2016
COD problems?
Here you go:
http://adamcook.wordpress.com/2008/04/04/how-to-get-flawless-online-gaming-with-your-ps3/
Belkin... | Answered on Oct 22, 2016
Hi!
If you don't remeber the wireless security code, maybe you still remeber the user and password to access the web management interface of the router.
Then you have to connect the laptop to the router by using a network cable. Open a browser window, type in the IP adress of your router and check the wireless setup section. There you can find / modify the wifi security code.
If you don't know the router's IP adress, then open on your computer a ms-dos prompt and type the command
ipconfig /all
it will display your current IP adress, subnet mask and GATEWAY. The gateway adress is the router's IP adress that must be typed into the browser.
If you don't remember the user and password for accessing the router's web interface, please refer to the router's user manual in order to reset it to factory default configuration, and then proceed as for the first installation of the router.
Hope it helped,
Bogdan
Belkin... | Answered on Jun 13, 2016
Do you have some kind of hardware attached to your router from Netflix? My understanding Netflix is Internet base and can be use by a multiple devices like PS3 $4 WII Xbox I believe and some of the DVD players which is direct ether net port or via wireless connection. Unless your router is asking for a static IP and do the port forwarding... let me Iif this one help
Belkin... | Answered on Jul 07, 2015
connect any one of the computers to the router with a ethernet cable. open internet explorer, clear out the address bar on the top, and type 192.168.2.1. when u hit enter, u'll get a router set up utility. in this page u'll have an option -security- below "wireless". when u click security, it'll ask for a password, leave it blank and hit submit. on the next window, choose the option WPA/WP2, then u'll have some more options, look for PASSWORD(PSK).. put in a password which should be 8 to 63 characters long, its case sensitive. click on apply changes.
Belkin... | Answered on Feb 06, 2015
Belkin (F5D8231-4) Wireless Router (F5D82314) Logo
460 questions posted
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Ekse
Pamela Bates
Pamela Bates
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
  • Belkin Computers & Internet
Most Popular Question
need assistance seting up belkin router
  • Computers & Internet
