After replacement of batteries, universal remote controls, need to have setup with the device, using device codes. Just find out the setup code for Admiral TV, and setup the remote with it. Setup proceedings, and code lists are given in detail in this site. 'Electro-help' is the site name. Type in 'electronicshelponline.blogspot' in your browsers' search box, and click search. It is a blogspot site in English language. Pull up older posts there. You can get all details you want from here. If you want further assistance from me, inform me by Fixya.
first try a new set of connecting wires these are the usually cheap wires that will give out easily. if that don't work ,its most likly gonna be the tape recorder itself. how old is it.
Code 001 for Admiral TV
Code 046 for Admiral TV
Code 047 for Admiral TV
Code 083 for Admiral TV
Code 095 for Admiral TV
Code 173 for Admiral TV
Code 191 for Admiral TV Try these if these won't work add a 1 in front of these codes to make it a 4 digit code and this should get you going. Good Luck
Using the buttons on the TV, go to the setup menu, and scroll to "edit channels" by pressing "setup" button until "edit channels" is highlighted. Then, using the channel up/down buttons, go to channel 91 and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
Using the buttons on the TV, go to the setup menu, and scroll to "editchannels" by pressing "setup" button until "edit channels" ishighlighted. Then, using the channel up/down buttons, go to channel 91and press + volume. This should add the video input to your channels. 92 is S-video. It is helpful to have what ever device (dvd player or game console) hooked up and powered on, so you know when you are on the right channel, but it should be 91.
You will need a menu button to get to setup or channels for you to autoprogram the tv to find ALL the channels. AUTOPROGRAM is the word you need to find. If there is a menu button on the tv, then you can probably do it from there. If not, then you need the original remote from Admiral or at:
YOU CAN USE EMERSON CODES FOR YOUR ADMIRAL TV AND TV / VCR COMBOS, MY COMCAST REMOTE ACCEPTED 11911. SOME REMOTES NEED FIVE NUMBERS AND MY ADMIRAL ONLY HAS THREE. SO I USED AN EMERSON CODE AND IT WORKED MOST OF THE BELLS, NOT ALL WHISTLES WORKED BUT I DIDN'T HAVE TO GET UP TO TURN IT ON, CHANGE THE CHANNEL OR THE VOLUME. MY KIDS WON'T DO IT ANY MORE!! GOOD LUCK!!!!!
