My tv screen is magnified.words on top andbottom dont fit . station logos in corners such as FOX or ESPN only show about half.when football game is on it doesnt show the score on top,but when i hit prev. channel it shows the whole screen for an instant b4 switching. i have comcast digital cable.
SOURCE: Picture size won't fit screen. Can't see scrolling text at bottom (e.g. sports scores on ESPN)
hi there,
its probably not the tv but the set top box you need to fix. go to the settings and select the mode you want ie. widescreen 16:9 etc
then go to the tv and select the full mode or widescreen mode at 16:9
that should solve your problem. it takes some time to find the combination between the set top box and the tv to get it right
good luck
smeags
SOURCE: I have a Pioneer SD
It's likely that you've changed the screen format to a different ratio. There should be a button on your original Pioneer remote, marked "MODE" with "SCREEN" written above.
The change the screen ratio, put your TV on a channel where you can see sports scores or the news tickers, then press the "MODE" button repeatedly until they are the correct size and in the correct position. Each successive press of the "MODE" button will cycle through the options for "NATURAL WIDE", "CINEMA WIDE", "ZOOM", "FULL" and "NORMAL"
I suspect you have accidentally pressed the "MODE" button and are in "ZOOM" mode. You probably need to be in either "FULL" or "NORMAL" modes depending on your viewing requirements.
It may also be necessary to adjust the vertical (V) position on the picture. If you have changed the mode settings as above but it's still not correct, please post back if you need information on changing the picture position.
Regards,
BElectric
