20 Most Recent Hitachi 43F300 43" Rear Projection Television Questions & Answers
Hitachi 43F300 TV no audio or video probs
Could you have bumped the wrong button on the remote? Make sure the TV's input is set to where the DVD is connected. murf427
8/4/2012 5:30:56 AM • Hitachi 43F300... • Answered on Aug 04, 2012
Service manual 43F300
Hitachi will have it but for authorized repair centers and online---you can try to Google the model number to see if one is available online from another source.What are you needing the manual for? What is the trouble?
6/13/2012 2:54:42 PM • Hitachi 43F300... • Answered on Jun 13, 2012
Magic focus is not clearing my problem ..what can be done ?
disconnect and reconnect to reset...then double check all settings and wiring...also, clean for any dust particles
2/5/2012 12:49:29 AM • Hitachi 43F300... • Answered on Feb 05, 2012
There is a constant blue shadow and yellow bowing
Please do us a favor and rate this by cliking the thumps up icon located here >>>>>>
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Below are more details for both items. Also, complete repair kits with instructions and repair support are avail from site such as www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
6/2/2011 4:27:50 AM • Hitachi 43F300... • Answered on Jun 02, 2011
2answers
Looks like its in 3d
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
  • Screen looks 3D
69189a5.pngSOLUTION
5/18/2011 12:28:06 AM • Hitachi 43F300... • Answered on May 18, 2011
The projection off my t.v.
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
5/9/2011 1:43:57 AM • Hitachi 43F300... • Answered on May 09, 2011
0answers
Volume is working fine, but no picture. its blank
OK well what has happened i suspect, is that your set has been "Spiked" from a power disturbance, and this has damaged either the PSU, or an internal high voltage component, or both, and now, the Protection Circuitry in the SMPS unit, is "Sensing" a potential "Catastrophic fault", that may cause a fire an explosion or both, and accordingly the set MUST be shut down, so the protection circuitry does exactly that.
Your best bet, is to contact a local or head office of the TV's manufacturer, and ask them for a referral to an authorised servicing center. When contact is made with them, ask for a "Quote" for the repair, before allowing any repair work to be undertaken. This then at least will give you an idea as to costings and you can then make an informed decision as to repair or replace, as often these days i find in my shop anyway, many repairs can be very expensive, and often it would be better putting any monies that would have been spent on repair towards a NEW unit with a warranty.
3/2/2011 4:35:37 AM • Hitachi 43F300... • Answered on Mar 02, 2011
The top part of the screen has red and green going
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
1/13/2011 6:39:13 AM • Hitachi 43F300... • Answered on Jan 13, 2011
Double images and bright pink
Projection TV sets are known to have two common problems. The first problem that is common to these sets is convergence failure. When this happens the TV will usually look 3D, Wavy/Distorted, etc. It may also shutdown and blink an error code.
The second common problem with Projection TV sets is dull video, halos around objects, white looking video, or red overpowers the screen. This is commonly caused by the fluid in the lens being clouded over.
You can find more details and solutions here on Fixya at the following link below. Or click HERE
3d884ac.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
12/21/2010 4:15:00 AM • Hitachi 43F300... • Answered on Dec 21, 2010
The picture looks like "double
Bad STKs, Probably STK 392-120, upgrade to STK 392-150 thru 180 depending on what you can afford, from what I have read it's better to go with the higher number. Just search for the stk or tv model number and convergence and you'll find all sorts of guides on how to do the repair. You'll need a soldering iron
10/16/2010 12:04:04 PM • Hitachi 43F300... • Answered on Oct 16, 2010
The picture is bowed and you can see double and
convergence ic stk----- you can repair this yourself if you can solder you can obtain ic.s from matt electronics or any electronic suppliers locate the convergence ic.s on chasis there will be 2 the number will start with stk- most likely stk-392-110 hope this helps
10/10/2010 6:03:00 PM • Hitachi 43F300... • Answered on Oct 10, 2010
Red, green, and blue lines at bottom of screen
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
8/14/2010 4:41:03 AM • Hitachi 43F300... • Answered on Aug 14, 2010
How do I work magic focus
just hold buttom in
6/30/2010 2:31:19 PM • Hitachi 43F300... • Answered on Jun 30, 2010
Green and pink distortin upper left conner of
bad convergence control ic's
6/10/2010 12:59:10 AM • Hitachi 43F300... • Answered on Jun 10, 2010
Hitachi 43F300 43" Rear Projection Television Logo
79 questions posted
Top Hitachi Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Hitachi Televison & Video
Most Popular Question
service manual 43f300
  • Televison & Video
