20 Most Recent Mag Innovision InnoVision XJ 717 Monitor Questions & Answers
Sony videoscope XBR - Side by Side screens can't change it back.
Sounds like your TV has a PIP (picture in picture) that allows your AVI (audio visual input) to be viewed simultaneously with your cable input. Check the manual for the correct buttons, but the one you're looking for says either PIP or AVI or something along those lines. Hope this helps
4/13/2011 8:45:39 PM • Mag Innovision... • Answered on Apr 13, 2011
Sony videoscope xbr
the problem is most likely to be found on the HOrizontal Output Transistors note their numbers and replace them.this transistors are usually mounted on huge heatsinks.
3/19/2011 11:45:42 PM • Mag Innovision... • Answered on Mar 19, 2011
Mode not supported. That's what I see when I
Your PC video resolution is set too high for the monitor to display, you need to lower to the highest the monitor can support and for the best picture.
http://www.fixya.com/support/r4873371-fixing_out_range_format_not_supported
7/9/2010 2:36:44 AM • Mag Innovision... • Answered on Jul 09, 2010
Picture has shrunk and has lines
loose board solder...
5/9/2010 3:59:12 PM • Mag Innovision... • Answered on May 09, 2010
I'm trying to plug my sata hd into my esata DVR
What you can do is go to a good computer hardware store like, new egg. or somewhere that sells core hardware for computers. you should be able to buy a PCI-E or a PCI ESata card so you can plug it in. hope this helps!
4/6/2010 2:19:38 PM • Mag Innovision... • Answered on Apr 06, 2010
2answers
How do you get your computer out of sleep mopde
hello. Just push the start button. Joe
3/19/2010 3:22:44 AM • Mag Innovision... • Answered on Mar 19, 2010
Hey , i have Mag 900P monitor and i cant see
Hello there !
There could be a problem with the picture tube it could be dead( shorting) or the tube Transformer s damaged another course of this could be at the Horizontal section ie a Transistor or a Diode could be shorted .
Pls tell ur Technician to check all this .
Lastly Buy a new Monitor .
Good luck
12/5/2009 11:49:12 AM • Mag Innovision... • Answered on Dec 05, 2009
My lt717s monitor displays a small box saying mode
Try to change the refresh rate of your monitor and/or reduce the resolution.
Best Regards
10/22/2009 4:18:39 PM • Mag Innovision... • Answered on Oct 22, 2009
I have a 32
its overheating or the lamp is bad, get some canned air and spray the inside with the air.
9/30/2009 7:58:27 PM • Mag Innovision... • Answered on Sep 30, 2009
2answers
A line shows vertically on our monitor at all
I would try a degauss first, see that that gets rid of it.
9/9/2009 9:01:33 PM • Mag Innovision... • Answered on Sep 09, 2009
2answers
Recently been experiencing double vision on my tv
What you are seeing is the high frequency equivalent of an echo. This is normally caused by external received signal problems rather than the set itself. Note that one of the images is stronger than the other; this is the primary received signal. The weaker one is occurring a few microseconds later and is being received as a reflection from a building or a poorly terminated cable. Repositioning your antenna or replacing your cable will probably help a lot.
6/7/2009 12:47:56 AM • Mag Innovision... • Answered on Jun 07, 2009
3answers
Sony Videoscope XBR tv
This is usually a convergence problem.. Could you update this with the model number please. That will allow me to give you some specifics about what could be wrong and how to fix it.
Dan
6/2/2009 4:34:38 AM • Mag Innovision... • Answered on Jun 02, 2009
Whites look pink
this is a ez one go to setting and change the brightness if that dose not work tll me at [email protected]
5/29/2009 8:09:33 PM • Mag Innovision... • Answered on May 29, 2009
2answers
Desktop computer
It depends on what kind of programs he needs to work. I work with AutoCad 2008 and Google Sketch Up Pro Version 6 for my Architectural work on a low end PC. With a Pentium 4 @ 1.5 GHz, 512 MB RAM, and a small HDD, so you do not need much. Pretty much the cheapest new PC you can buy would be perfect. Hope I Helped!
1/28/2009 8:24:39 AM • Mag Innovision... • Answered on Jan 28, 2009
Red words under the words
ptc or decosing coil is bed or notworking proper so u have replace it
1/15/2009 12:45:29 AM • Mag Innovision... • Answered on Jan 15, 2009
Sony Videoscope XBR
from experience i have noted that after some time the Horizontal Out-put Transistor (HOT)gets worn out.This is a big black transistor starting with cd,d,t etc mounted on a big heatsink.note the numbers and replace it.
12/20/2008 1:05:04 AM • Mag Innovision... • Answered on Dec 20, 2008
Television
replace the horizontal transistor near the EHT.
8/30/2008 2:07:44 PM • Mag Innovision... • Answered on Aug 30, 2008
3answers
My monitor was fine for
check the cable connected to the monitor run another monitor on your pc and if it does the same , try installing a serarate graphics board and if you are already doing that, replace that graphic board
5/23/2017 7:57:08 AM • Mag Innovision... • Answered on May 23, 2017
Mag Innovision InnoVision XJ 717 Monitor Logo
30 questions posted
Top Mag Innovision Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
View Most Popular
XJ Mag Innovision
  • XJ Mag Innovision
Most Popular Question
hey mag 900p monitor see
  • Computers & Internet
