Need remote control codes for the JVC Multi Brand Remote Control Unit, LP20303-018
It took me a week to find the right instructions and codes on how to do
this so I am posting it everywhere I can to help out folks with the
same remote. Pay close attention to the instructions, for instance when
programming the remote for TV use make sure you hold the TV button down
while you enter the code and then press OK, You also have to hold the
TV button down while you use the volume and channel controls or it will
just change the VCR channel.
A
Turn on TV
Turn on the TV using the Power button on the TV or its Remote.
B
Set TV brand code
A
Press and hold TV.
B
Press MBR SET.
C
Press the Number keys to enter your TV.s brand code.
D
Press OK, and release TV. The TV should turn off.
C
Operate TV
While holding down TV, press one of the following buttons:
POWER 1, TV/VCR, TV CH+/., ^(TV Muting), TV VOL+/.,
and the Number keys.
For some brands, you must press ENTER after having pressed the
Number keys to enter a channel number.
TV BRAND CODE TV BRAND CODE
JVC 01, 03
SONY 07
HITACHI 10
SAMSUNG 12
MAGNAVOX 02
SANYO 13
MITSUBISHI 03
SEARS 13
PANASONIC 04, 11
TOSHIBA 08
RCA 05
ZENITH 09
SHARP 06
Cable Box or DBS Receiver Brand Setting
A
Turn on cable box or DBS receiver
Turn on the cable box or DBS receiver using the Power button on
the unit or its Remote.
B
Enter brand code
A
Press and hold CABLE/DBS.
B
Press MBR SET.
C
Press the Number keys to enter your cable box.s (or DBS
receiver.s) brand code.
D
Press OK, and release CABLE/DBS.
C
Operate cable box or DBS receiver
While holding down CABLE/DBS, press one of the following
buttons: POWER 1, TV CH+/., and the Number keys.
To change the cable box.s (or DBS receiver.s) channels, press TV
CH+/–
or the Number keys. (The CH+/–
button can be used to
change the VCR.s channels only.)
CABLE BOX BRAND CODE
ARCHER 01, 05, 17
CABLETENNA 01, 17
CABLEVIEW 15, 16, 17, 21, 25
CITIZEN 15, 16, 17, 21, 25
CURTIS 02
DIAMOND 01, 17
GC BRAND 15, 16, 17, 21, 25
GEMINI 15
GENERAL INSTRUMENTS 01, 04, 06, 11, 12, 15, 28
HAMLIN 10, 18, 23
JASCO 15
JERROLD 01, 04, 06, 11, 12, 15, 28
NOVAVISION 02
OAK 07
PANASONIC 13, 14
PULSER 15, 16, 17, 21, 25
RCA 13, 14
REGAL 10, 18, 23
REMBRANDT 01, 16, 17
SAMSUNG 05, 16, 24
SCIENTIFIC ATLANTA 02
SIGMA 07
SL MARX 05, 16, 17, 24, 25
SPRUCER 13, 14
STARGATE 05, 15, 16, 17, 21, 24, 25
TELEVIEW 05, 16, 24
TOCOM 01, 04, 16
UNIKA 01, 17
UNIVERSAL 16, 17, 25
VIDEOWAY 03, 09, 22
ZENITH 03, 09, 22
DBS RECEIVER BRAND CODE
JVC (DISH Network) 51
ECHOSTAR (DISH Network) 51
SONY (DSS) 41
RCA (DSS) 40
Changing Remote Control Code
This Remote is capable of transmitting two control codes; one set
to respond to A code control signals and another set to respond to
B code control signals. This Remote control is preset to send A
code signals because your VCR is initially set to respond to A code
signals. You can easily modify your VCR and the Remote to
respond to B code signals. When using two JVC VCRs, set two
VCRs and their Remotes to different codes, so that you can
operate these VCRs separately.
A
Set remote control code for Remote
A
Press and hold A/B.
B
Press the Number key .2..
C
Press OK, and release A/B.
The Remote now can transmit B code control signals.
B
Check remote control code for VCR
Press and hold 4
on the VCR for more than 5 seconds while the
VCR is turned off. The code currently set appears on the display
panel.
C
Change code for VCR
Press any key on the Remote. The VCR now responds to B code
control signals.
To set the Remote and the VCR back to A code control signals,
repeat the same procedure as shown above except pressing the
Number key .1”
in step B
of 1
1111.
To control two VCRs with the same Remote
You can control two JVC VCRs by switching the remote control
code for the Remote between A and B (.
step A
AAAA), keeping two
VCRs to different control codes.
To change only the remote control code for the Remote, DO
NOT perform steps B
BBBBand C
CCCC.
Only 1 and 2 work to change channels
