20 Most Recent Samsung TV Remote Control Questions & Answers
The Cox URC-7820B is not the one shown in the picture.Guess that's the Samsung LCD TV.
Here is the Manual for the 7820B, which is the Learning version of the 7820. Learning means if the TV codes for Samsung in the Manual do not work, then you can Learn them from the Samsung Remote by pointing their IR light(LEDs) at each other and follow the Learn the instructions in Manual:
www.urcsupport.com/images/uploaded_images/Cox_M7820.pdf
Samsung TV... | Answered on Jul 05, 2019
It the TV button flashes, try pressing that button again before channel changing.
Samsung TV... | Answered on Apr 11, 2019
On blu ray remote control hold down TV Power+01 at the same time. If the TV turns off the controller is programmed. If not, try TV Power+02, +03, +04, +05, +06, +07, +08, +09. Different TV BRAND??? ...TRY http://remotes.com/remotes/documents/Samsung/AK59-00104K.pdf
Samsung TV... | Answered on Mar 05, 2019
It is defective, call Samsung.
Samsung TV... | Answered on Jan 11, 2019
If Samsung 00026B remote is compatible with 0026b remote, any one tell me
Samsung TV... | Answered on Jan 07, 2019
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Samsung TV... | Answered on Dec 27, 2018
Yes. I found the code. To operate Samsung HT-Z 310 with a remote control of Samsung TV, You have to turn off DvD, and then select Dvd on the remote(press the dvd button), press SET on YOU
remote control, input the CODE(020). For different Samsung dvd. you can try.codes from 000-to 080. The DVD button must blep three times. After that swich on Dvd. Enjoy....
Samsung TV... | Answered on Nov 21, 2018
is there a text center
Samsung TV... | Answered on Nov 07, 2018
Trying to operate a Samsung BluRay player, Model BD-C5500/XAA
Samsung TV... | Answered on Aug 30, 2018
Being a Samsung, I would suspect the power supply.
Samsung TV... | Answered on Jan 18, 2018
Don't be afraid to pry the case open. It has plastic tabs along the sides that hold it together.
Samsung TV... | Answered on Nov 29, 2017
Try these codes in your universal remote. One of them should work for your model.
1053
1056
1057
1059
1060
1061
1083
1004
1007
1018
1047
Samsung TV... | Answered on Jul 24, 2017
On TV remote press Mode button or TV button. Then select HDMI 1 or HDMI 2 depending on where the cable is inserted in the TV. Now press the SET button & enter the code. Try the following codes:
0019 0618 0644 0056 0060 0587 0037 0178 0030 0556 0009 0702
0774 0093 0217 0448 0747 0482 0370 0264 0329 0090 0032 0216
0290 0154 0150 0092 0072 0179 0208 0519 0156 0163 0625 0226
0812 0817 0821 1060..
If the above codes don't work contact TV manufacturer for the code.
Samsung TV... | Answered on Nov 13, 2016
some remotes used to have a key to switch between single or double digits marked ( -/--)
Samsung TV... | Answered on Sep 21, 2016
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window" to get gathered related posts.
Samsung TV... | Answered on Sep 19, 2016
Check for a stuck/pushed in button or try and remove/reinsert batteries.
Samsung TV... | Answered on Sep 11, 2016
Samsung TV Remote Control Logo
546 questions posted
Jerry Greenberg
Jerry Greenberg
Ekse
View Most Popular
  • Samsung Televison & Video
Most Popular Question
adjust picture full screen
  • Televison & Video
