20 Most Recent
Sharp RRMCG1687PESA Remote Control Questions & Answers
TV remote has a problem.
I need model number of your 20 inch Sharp tv to diagnose problem.
Let me know model number as it would be written on label pasted at back of tv.
Remote control can be tested by watching its front through any digital camera because our eye can not see infra red light signal of remote, press keys on remote, if infra red light blinks in remote front that means remote is working and problem could be with tv.
Thanks.
3/20/2015 4:42:02 AM •
Sharp...
Answered
on Mar 20, 2015
When i start my tv automatically turn-off like we turn-off by remote control.
Just close the infrared sensor window at it front panel with any opeque material, like a diary or so. Then try to switch it ON. If the set behave so, even after blocking the infrared sensor, make sure that there is something fault with the main system control section. Need a through checkup. If it switches ON without any problem now, make sure that there is no energy saving lights; like CFL or so, in front of the TV.
7/11/2012 3:00:55 AM •
Sharp...
Answered
on Jul 11, 2012
Sharp Remote Control Problem
trying removing the batteries and reinstalling then the reset the remote and then tell me if it works if you have lock the parental function on sould like
1/4/2009 12:47:28 AM •
Sharp...
Answered
on Jan 04, 2009
How can I make the text sharp on Magnavox model 22ME601B/F7?
- Check HDMI Cable Connection: If you're using an external device like a cable box, gaming console, or streaming device connected to the TV via HDMI cable, ensure that the HDMI cable is securely plugged into both the TV and the external device. A loose connection can cause intermittent resolution adjustments.
- Adjust Picture Settings: Navigate to the TV's menu and check the picture settings. Look for options related to display resolution, aspect ratio, or picture mode. Ensure that the settings are configured correctly for your viewing preferences. Try resetting the picture settings to default and see if the issue persists.
- Update Firmware: Check if there are any firmware updates available for your TV. Sometimes, software updates can fix bugs or issues related to display resolution adjustments. You can usually check for updates in the TV's settings menu or visit the manufacturer's website for instructions on how to update the firmware.
- Check Signal Source: If you're experiencing resolution adjustments while watching content from an external device, such as a cable box or streaming device, make sure the signal source is sending a consistent signal. Issues with the signal source can sometimes cause the TV to adjust its display resolution.
- Reset TV: Try performing a factory reset on your TV to restore it to its original settings. Keep in mind that this will erase any customized settings and preferences, so you may need to set up the TV again after the reset.
- Contact Magnavox Support: If the issue persists after trying the above steps, it's possible that there may be a hardware problem with the TV. In this case, it's recommended to contact Magnavox customer support for further assistance or to inquire about repair options.
By following these troubleshooting steps, you should be able to diagnose and resolve the issue of your Magnavox TV constantly adjusting its display resolution.
Hope this helps
How do I operate Sharp LCD TV remote control
First of all
1. **Power On/Off:** Use the "Power" button.
2. **Changing Channels:** Use "Channel Up" and "Channel Down."
3. **Adjusting Volume:** Use "Volume Up" and "Volume Down."
4. **Input Selection:** Use "Input" or "Source" to choose input devices.
5. **Navigating Menus:** Use navigation arrows and "Enter" or "OK."
6. **Mute Function:** Use the "Mute" button.
7. **Number Pad:** Input channel numbers or perform numeric functions.
8. **Special Functions:** Access features like "Menu," "Exit," "Subtitle," or "Info."
9. **Teletext/Closed Captioning:** Access these features if applicable.
10. **Smart TV Features:** Access smart features, apps, or online content if applicable.
11. **Batteries:** Ensure the remote has fresh batteries for responsiveness.
For model-specific details, always refer to your Sharp TV's user manual. If you provide your TV's model number, I can offer more tailored instructions.
Changing analog to digital on Sharp TV
Unfortunately, you cannot convert an analog TV to digital simply by changing settings. The transition from analog to digital involves hardware changes. If you have an older Sharp TV without a built-in digital tuner, you may need an external digital converter box or consider upgrading to a newer TV with a built-in digital tuner to receive digital broadcasts.
