Bottom rack only
SOURCE: I am attempting to install
Remove the hose from the disposal, take a hammer and long screw driver, put it in the hole where the hose attaches and knock the plug out. Turn power off to the disposer and pull the plug out of the disposer. Hope this helps.
SOURCE: Kitchenaid, new dishwasher, stopped cleaning top rack dishes
The problem most people encounter with dishwashers is a simple inability to get the dishes clean. There might be stuck-on food
or residue from the detergent. A water pressure problem may be the
culprit. You may need to replace the water intake valve. Another common
problem is mineral build-up. If your house has hard water, the mineral
build-up can clog the water jets. Clear each jet with a wire or pin,
and run an empty load with some vinegar in the detergent dispenser
about once a month.
Sometimes, the dishwasher has problems draining properly. There could
be a clog in the drain hose, or a problem with the pump. It's also
possible that the dishwater is getting too sudsy, and sensors in the
washer aren't detecting the soap foam as water. This causes it to shut
down the drain cycle too early. Just use less detergent.
SOURCE: How do you remove the upper dishwasher rack? It's
The upper rack is held by four side brackets. They are not removable unless you pull the dishwasher out from under the cabinet. Not very homeowner friendly.
SOURCE: Top rack whisperquiet dishwasher no water
http://www.kitchenaid.com/assets/pdfs/product/ZUSECARE/8573754.pdf
I know this isnt the same model, they dont carry your manual as of yet. But it does have some suggestions to look at on page 17. I had the same problem and I looked really carefully and found my sprayer arm was blocked. I cleaned it out and havent had a problem with it again. I do check it regular now.
SOURCE: Our kitchenaid dishwasher is not cleaning well
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
Hello &
Welcome to FixYa
When the
dishwasher fills then it means that the control and the water inlet valve are
fine, hum sound itself indicates that the motor is bad and needs replacement.
If you hear a hum sound from the bottom of the unit then it is the motor that
is bad and if the hum comes from the control then it is the timer that is bad
and needs replacement. Please get back to me if you have any other questions.
Kevin
