20 Most Recent KitchenAid KUDS50FVSS Builtin Dishwasher Questions & Answers
Need more info. Are you asking about a dish washer or clothes washer?
KitchenAid... | Answered on Jan 22, 2018
Check the breaker box for a tripped breaker. If it is tripped then flip it back on. If it trips again call a repairman, you probably have a short.
KitchenAid... | Answered on Oct 25, 2013
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101;'
KitchenAid... | Answered on May 01, 2011
Hello & Welcome to FixYa
When the dishwasher fills then it means that the control and the water inlet valve are fine, hum sound itself indicates that the motor is bad and needs replacement. If you hear a hum sound from the bottom of the unit then it is the motor that is bad and if the hum comes from the control then it is the timer that is bad and needs replacement. Please get back to me if you have any other questions.
Kevin
KitchenAid... | Answered on Dec 11, 2010
Sound like the is a problem with one of the supply pipes for the water check they are not blocked and the is no turn off on
KitchenAid... | Answered on Jul 06, 2019
There are several touch pad buttons that could activate the Child Lock feature on a Kitchenaid dishwasher. To toggle off the lock, try pressing and holding the 4-hour delay dry or the energy saver dry key pads for 4+ seconds. The Energy Saver Dry is used for the Child Lock on the Kitchenaid KUDS25SHWH1. This manual is here: https://c.searspartsdirect.com/mmh/lis_pdf/OWNM/L9050329.pdf . The 4-hour delay or Control Lock options are listed in this manual: https://www.kitchenaid.com/content/dam/global/documents/201605/owners-manual-W10596243-RevD.pdf . If neither of these steps work, you may have a problem with the keypad, the wiring between the keypad and the control board or the control board itself.
Please add a comment with the model of the dishwasher if you'd like me to try and find the parts list/diagram. If the machine is under warranty, you may want to contact Kitchenaid.
I hope this helps.
KitchenAid... | Answered on Jun 30, 2019
I experienced the same problem after my tension cables broke. The door fell open with such force that it bent the hinges a little. If you've replaced the tension strings (which you should do every 5-8 years) then you don't have to replace the latch. I did and it didn't solve the problem.
Here's the solution:
Put a towel at the bottom of each side of the door by the hinge.
Push the door closed a couple of times to bend back the hinges.
Remove the towels and you're back in action.
Good luck
KitchenAid... | Answered on Jun 22, 2019
Sounds like control board failure
KitchenAid... | Answered on Jun 13, 2019
KitchenAid KUDS50FVSS Builtin Dishwasher Logo
15 questions posted
Top KitchenAid Dishwashers Experts
Mike
Smitty
Level 1 Expert
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • KitchenAid Dishwashers
Most Popular Question
not clearning properly leaves white
  • Dishwashers
