LED turns green, sound is good but no picture..
Is this a plasma or an LCD TV? If it's an LCD TV then I would check the backlight inverters. If it's a Plasma TV then The Sustain boards there are two sustain board.
You can get parts for this TV at www.interliquidparts.com
SOURCE: Hitachi 32LD8700 - TV won't turn on although has power
The general problem with LCD type TV's is that the power supply
fails. They are very sophisticated designs that are difficult to
troubleshoot and generally best to just replace the module, but
sometimes there is visible damage in some of the electrolytic
capacitors (visibly bulged) and high voltage rated parts can be
substituted.
Hope Ya Fix It
SOURCE: black screen
first try the address board or buffer board.if this
does not repair it,the panel is defective.
SOURCE: screen went black on my 42" sanyo model dp42647 lcd
Hi there! The panel may be in protection mode. The Inverter board is the most logical area to start after checking power supply Voltages.(5,6,24 and 13Volts). There may be coils on the Inverter Board which have bad soldering or faulty. Other than this it may be main board which controls switch on or off. If all else fails, refer to a repairer. Beware of High Current!!! Best Wishes and Good Luck, Jus004
SOURCE: Toshiba 42HP66 No Picture, Only Power Works
try replaced z board Manufacturer Toshiba Part Number 75003032 Description ZSUS PCB ASSY
SOURCE: Phillips Flat TV Model 20pf4121\105 (Flashing green led)
electrolitic capacitors 1000mf /10 v in pover unit
