Jenn-Air WW30430P Stainless Steel Electric Double Oven Logo
Rita Young Posted on Sep 03, 2006
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The oven door are not closing all the way
The oven doors don't seem to close all the way. there is a gap between the door and the oven. Heat can escape.
  • 7 more comments
  • Anonymous Nov 04, 2007
    I have same problem..new hinge did not remedy situation...unit is only 3 years old and I am replacing it with a GE Momogram Trivection. I am sick and tired of waiting for a baked potato to take 2 hrs to cook
  • tbear333 Nov 26, 2007
    same problem, ovens 2 yrs old.
  • Fishcleaner Mar 29, 2008
    My Jen Air oven door is not closing all the way
  • Anonymous May 31, 2008
    the lower oven door does not close tightly, the light is always on.
  • Anonymous Aug 12, 2008
    same problem door does not close all the way
  • dgelfenb Mar 24, 2009
    Lower oven door does not close alll the way
  • Anonymous Mar 18, 2014
    the oven door does not close properly, allowing heat to escape. How do you adjust this ?
  • Anonymous Mar 21, 2014
    My oven door has a gap at the top about 5mm- 7mm how can this be fixed?
  • Anonymous Mar 24, 2014
    The door closes without any obstruction yet the door remains unsealed allowing heat to escape
Anonymous
Level 3:
President:
  • Master 878 Answers
  • Posted on Sep 03, 2006
Anonymous
Master
Level 3:
President:
Answers
878
Questions
Helped
1202234
Points
3312
Spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
My oven door leaves large gap at top when closed. lot of heat escapes there. can i fix that
You may need to open the door and adjust the hinges that are attached the door itself as well as the ones connected to your stove..
Apr 02, 2018 • Ovens
1helpful
How do I fix an oven door
sounds to me like bottom hinges are set to close to oven/ need spacers so oven door closes flat top and bottom at moment it seems that bottom is to tight before oven door is closed ,try fitting spacers behind hinge fixings at bottom, good luck
Sep 22, 2016 • Ovens
The door will not close completely
Hi someone lifted up on the door this ishowyou remove oven doors open the door about 1/3 then push down towards the floor it should go back into place, if not you may have to remove it clean the hinges then re-install it , I don't think anyone could have bent the hinges cause that would b very hard to do, but i have seen it done before , get back to me Frank
2answers
Eog 6330 oven door does not fully close ie small gap at top unless you hold door closed are hinges damaged or bent?
you will have to replace both left & right hinges / this should correct problem .. mm
Euro maid sc1531 oven door dose not close at the top
Did you solve your problem???? Cause I am having the same problem :( I would really appreciate it if you could let me know Thanks
Jul 04, 2010 • Ovens
8helpful
2answers
Oven door not closing properly
If it is a drop down door with hinges on the bootom of the oven door, then it is likely to be weak door hinge springs, the usual solution is to replace both hinges.
If it is a swing open door, then the problem is related to a worn or broken door catch, or worn striker pin.
Apr 13, 2010 • Ovens
Oven takes forever to heat up - its a thermador double oven - me272
Hello- Check these things first-  Door seals tend to get stiff over time. This is normal. Door hinges can become loose or get bent a bit, causing door to not close tight. This little gap can allow heat to escape, causing extended pre-heat times and frequent cycling of elements. If door doesn't seem to pull shut tightly- hinges will need to be replaced. If oven appears to operate normally otherwise, this should solve problem.  Let me know if the info helps- have more if needed- Thanks  - Ed
We have a 30 in prostyle electric double wall oven - the oven takes forever to preheat and the doors do not seal tightly when they are closed.
Hello- Many ovens use spring-loaded hinges to carry the weight of the door. Over time, these springs weaken or the hinge gets bent just enough to not fully close door. The door gasket can also become flat and stiff, compounding problem. Any small gap releases heated air, and oven will not heat up properly. Replacing the door springs should solve problem.- Thanks -Ed
Door does not close all the way when baking
Hi!!! your door hinges are bad they need replacing..very expensive fix..So look around..Good luck..
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 • Ovens
Top Jenn-Air Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
