est the high voltage capacitor,the rectifier diode.or the magnetron. If all this are fine, test the control board.
Thediode
and capacitors can br tested. The capacitor must bealloweddischarge
before testing, or you risk to get electrocuted, evenifpower is off.
Capacitors can get discharged by shorting theirtwocontacts.
Before replacing the magnetron test also the control board.
Replace the magnetron if the checks and all of the high voltage component tests are good, but the unit still does not heat.
All locations, and description of this parts can be located using the diagram here:
Counter top.
Parts must be tested to find out what is wrong.
Remember that microwaves are potentially dangerous devices if not repaired properly, the job must be done by a competent person.
A microwave energy leakage test must always be performed when the oven is serviced for any reason.
Regarding parts,
contact the seller here to purchase parts.
My lg microwave gives me a warning signal on the display , like the rombus and a exclamation mark inside !) and none of the keypades work
LG mocrowave does not heat food, spins slight noise, the grill works but it just wont heat food
