If the oven is dead - no display, no beeps when you press a pad on the keypad, and no inside light when you open the door - then I would suggest that you very the outlet is okay
under load.A hair dryer or toaster are the best ways the average DIYer can test the outlet under load.If that's good, then your microwave may be dead due to a blown fuse, magnetron thermostat, or oven cavity thermostat.
There
should be a "mini-manual" (tech sheet) hidden inside the unit
behind the
control panel or hidden on the left side behind the grille, which is
very helpful when troubleshooting, testing, and locating
components.At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
If the fuse and magnetron thermostat are good, then you will have to take the oven down from the wall to get to and test the oven thermostat.
You can find
helpful exploded view diagrams and order parts by entering your full
model number here.
We're
happy to help you with free
advice and we'd appreciate your thoughtful rating of our answer.
