20 Most Recent
GE JVM1860 Microwave Oven Questions & Answers
Buzzing noise.microwave not working
That's almost always a defective filter capacitor on the control circuit board.
We regularly repair such control units for
customers nationwide by mail for $39.95 postpaid in about a
week or so with a one-year guarantee.
At
our Web site, we have a video
available showing how to remove a typical
over the range control panel assembly in under 5 minutes.
Feel free to contact me directly (and please remind me of your
full model number from the tag on the unit) for more information & help.
We're
happy to help you with free advice and we'd appreciate your thoughtful
rating of our answer.
William E. Miller, AS-EET
[email protected]
http://www.microwavedisplay.com
Charcoal Filter Replacement
Be sure the oven is disconnected from the wall first.
Then open the door.
Remove the two screws from the top of the grille.
Next, slide the grille to the left to remove it.
Before you slide the charcoal filter out, be sure to note how it rests at an angle on 2 side support tabs and in front of the right rear tab.
After it's replaced, you can press OPTIONS until you come to the Charcoal Filter Reminder.
Then you can press 0 to turn the reminder off, press 1 to set the reminder, or press 3 to turn the reminder on.
Food Heats fine, but turntable wont rotate. Makes a loud noise until we press the
see this tips for to repair:
Inspect
the plastic drive coupling that the tray sits on, as well as the
ring-and-roller assembly, to make sure that they're working properly. First, make sure the turntable coupler under the glass
dish is not broken. Second, on the control board, find the turntable
relay and test for voltage. Some turntable motors are 24 volts DC, so
make sure your testing the correct voltage. If no voltage from the
control board, then replace the control board. Otherwise head towards
the turntable motor.On OTR models, you can get to the motor by
un-screwing the bottom panel on the microwave. On countertop models,
there will either be a knockout or screw on access panel. Check for
voltage at the motor. If no voltage, check the wiring back towards the
control. If voltage, then replace the turntable motor. The component
list below also shows how to test a turntable motor.
GE Microwave Oven JVM1860SF001 - Noisy fan
The fix is that the magnet inside the bottom of the motor eventually drops enough as it spins(plastic hat-shaped piece under it wears/crushes down) to rub on the bottom of it, where it is metal, causing the noise. You can easily remedy this by taking apart the motor, pulling out the magnet and plastic booster piece under it, placing a thin washer on the bottom to boost them up a bit, then reassembling. Problem solved and no need to buy some overpriced part and fill up the landfills with perfectly good equip!
Touchpad will not work after boiling water
you can change the touchpad to help with this but whenever you have a microwave over a range you are going to have issues with this. you have to make sure you use the vent on high whenever broiling anything to prevent the moisture from getting in the touch pad because all your touchpad consists of is two stickers and some flat wire so moisture can easily getting into it cause it to stop working for a period of time. but changing it is the best thing you can do
How to replace lightbulb inside microwave
Unplug the microwave from its electrical outlet. Never service an electrical appliance while it's plugged in.
Remove the screws that hold the
outer shell onto the microwave chassis. Often the screws are on the
bottom or back of the microwave. Use a Phillips screwdriver or Torx
driver to remove the screws.
Lift the outer shell off the microwave chassis and locate the box that houses
the halogen lightbulb. In most cases, the box is metal. It may or may
not have a lid on it. If it has a lid, loosen the tabs and pull off the
lid.
Unscrew the halogen bulb and replace it with a bulb rated at the exact same wattage.
5
Place the cover back onto the box if necessary and place the shell over the microwave chassis.
6
Secure the shell to the chassis with the original screws and the screwdriver or torx driver.
My wife overcooked a potato to a crisp in the
Without the full model number, I can only give a general answer.I would suspect that the overheating damaged the thermostat / thermal cutout that protects the magnetron. Hopefully it did its job.This most often occurs when the microwave is left to run unattended, a big no-no as mentioned in the owner's manual.
You can find
helpful exploded view diagrams and order parts by entering your full
model number from the tag on the oven here.We're
advice and we'd appreciate your thoughtful rating of our answer.
